911 Forum 1964-1989
dissect a 1989 coupe PPI
Old 07-12-2011, 12:38 PM
ro9beam2002
ro9beam2002's Avatar
Default dissect a 1989 coupe PPI
Here it is along with a list of mods that were done.. pics coming soon... Anyone know the rep of the garage that did the PPI... what would be a fair price or steal of a deal on the car? cars has 70 k miles He is asking 21k
The ppi was done 4 months ago The ppi and work below was done at "german auto group" in VA
Cylinder leakage test
1-96%
2-98%
3-99%
4-99%
5-98%
6-97%
CO hydrocarbon levels- 1.0%
Brake warning light on- n/a "big reds"
a/c- low.... "No cooling ducts for x-changers"
Sits to low
No heater pipe from fan in engine bay..."could be a fire hazard"
Battery at 12.06 volts "weak"
Front shocks weak
Some wear on front suspension linkage and bushings
Rear tires near wear indicators
Here is a list of what was repaired or done 3 months ago after the ppi at the same place...
oil-filter change
fuel filter
replace spark plugs
replace valve cover gaskets
replace air filter
tranny fluid change
perform valve adjustment
check chassis
check lights
check brakes
remove and pack outer front wheel bearings
$1,143.00
The mods listed below were completed by the previous owner over from 2003-2008
Old 07-12-2011, 12:43 PM
ro9beam2002
Pics
Old 07-12-2011, 02:05 PM
justin-in-athens
justin-in-athens's Avatar
23K market value
18K would be a deal
If the AC works that is a big plus on this car, also depends what part of the country you are in. In the southeast prices are considerably cheaper.
Old 07-12-2011, 02:21 PM
User 4221
User 4221's Avatar
It appears to be a Euro.
When was it brought into the country?
How was it Federalized?
Is the Federalization documentation available?
Is the mileage verifiable?
These are things that affect value significantly.
Old 07-12-2011, 02:23 PM
justin-in-athens
Nice catch scott!
Old 07-12-2011, 04:25 PM
vracer
vracer's Avatar
Headlight hi/lo switch? Relay added? Alternator/Voltage reg. age. Both are fairly common faults in G-50 cars.
Old 07-12-2011, 04:48 PM
ro9beam2002
The current owner has had the car for about 2 years and 6k miles...
3-4 owners... appears the car was brought in the US in 1991 at 43k miles....carfax at auction...
in 2002 it still only had 56k miles
Old 07-12-2011, 05:12 PM
dshepp806
dshepp806's Avatar
,..at "auction"?
Doyle
Old 07-12-2011, 05:34 PM
ro9beam2002
Yes, i assume it was sold at an auction in 1991 with 43 k miles.... "euro model"
Old 07-12-2011, 06:27 PM
dshepp806
dshepp806's Avatar
Is the current owner a car dealer? Just askin'...
Doyle
Old 07-12-2011, 06:31 PM
justin-in-athens
If he is a dealer you would have to consider sales tax too, as opposed to buying from a private seller.
Old 07-12-2011, 07:01 PM
ro9beam2002
No , he has owned the car for 2 years and 6k miles. He has the previous owner contact info as well...and he owned the car from 2003-2008
Old 07-12-2011, 07:06 PM
ro9beam2002
Also the car is not a euro "according to the present owner, he also thought it was a euro when he bought it"...... but he said the car does have side marker lights, narrow bumperettes, and transmission cooler found on the RoW cars. The vin starts with WPA0 and not WPZZ which would be a euro...
Old 07-12-2011, 07:39 PM
dshepp806
dshepp806's Avatar
wow,..that's weird,..someone comment on Euro-side marker adds...?
BEST!
Doyle
Old 07-12-2011, 10:01 PM
ro9beam2002
How are the leak-down numbers?
Quick Reply: dissect a 1989 coupe PPI
