AC Removal - Critter Hotel
I recently got the power put into the garage, then the heat and lights got done the following weekend.
Today I decided to take advantage of my new workable space and remove all the AC components.
I knew some critter had gotten in while the car was still outside, just didn't know where it nested.
Found this under the the evaporator box.
I have a couple of question though.
Does the protective bar in front of the condenser serve any structural purpose? Can I just leave it off and save that weight too?
also
I'm thinking I should put the screws back in as a means to plug up the holes.....yes......no?
also
I haddah Google dat
Oh, sorry - I would leave the bar anyway. It does serve a little bit of protection if you roll into a parking curb. Dunno 'bout the holes. Be sure to remove the ac relay.
Thanks rusnak,
I was wondering about how to deal with the electrical.
Yes, garage is insulated, R14 & R20 in the walls, R40 in the attic.
I got a 4800W blower fan that is running off a 30A 240V plug.
Takes about 40 min to go from -10C to +10C, then the duty cycle is about 5 min on 15 min off to maintain temp.
cheers
cheers
I haddah Google dat
I believe that would be brass, and since the evap is gone, probably the condenser is gone too, or empty. The bar does a good job of protecting the front of the car, particularly the spoiler from getting folded under by curbs.
After being sick most of the week, I was finally able to get back to the car today.
Yet another surprise!
I removed the windshield washer tank and discovered there was about 2 quarts of MOTOR OIL in the damn thing! It was floating on top of the windshield washer fluid.
I owe some previous moron for this little present. :-(
