help with 911 front hub Question
Does anyone know if the front hubs are the same from a 1978 911 sc to a 1988 911 carrera. I would like to know the size that they stick out from the rotor if possible. I was curious to run turbo hubs instead of factory hubs to eliminate running a spacer on a turbo bodied car. I believe there is an inch difference between the 2. Any info would greatly be appreciated!!
TIA
TIA
The Turbo front hub difference (IIRC) is 21mm. Be careful with the measurement as the rotors are different thickness..... The early 930 cars had a 21mm spacer and used the SC hub, the later cars did not use a spacer and had the 930 hub.....
Cheers
Cheers
