Parking Brake Question
When the parking brake is applied, the rear wheels on my car can be rotated back and forth about an inch at their circumference. This makes you jump when you stop on a hill, apply the parking brake, release the main brakes and the car rolls back
. Is this normal behaviour, or do I need to fix something?
Many Thanks,
Gordon
1986 3.2 Carrera.
. Is this normal behaviour, or do I need to fix something?Many Thanks,
Gordon
1986 3.2 Carrera.
Hi,
Two potential problems:
1) Parking brake cables out of adjustment or stretched.
2) Worn parking brake shoes.
I'd pull the rear rotors and look at the shoes before adjusting the cables for stretch.
"In gear?"
Good question.
No, it's not in gear. The behavior is the same for both sides. No hand brake, I can turn the rear brake disk easily by hand. Handbrake on, both sides independently turn freely maybe 10 degrees, and then clunks to a sudden stop. It's the same forward as backward.
If that's a problem, at least it is symmetric! When I get the disks pulled off I'll report if it looks like a problem or a "feature."
Good question.No, it's not in gear. The behavior is the same for both sides. No hand brake, I can turn the rear brake disk easily by hand. Handbrake on, both sides independently turn freely maybe 10 degrees, and then clunks to a sudden stop. It's the same forward as backward.
