Fan under passenger floor board?
I was tracking down a battery drain problem and found a hot wire coming directly off the battery (not going through the fuse panel) going to an electric fan that is mounted under the passenger floor board. I was not able to trace the other wire to a switch or relay. Can someone tell me what that fan is and why it might be hot wired to the battery? There is an in-line fuse, but that is it and it puts a draw on the battery when ignition is off.
Thanks for any help!!!
My guess? I think you have two auxillary fans for the heating system up front. One on each side. I think they come on when you pull up the red levers between the seats (they should go off when pushed back toward the floor). Maybe a bad switch that's not turning one/both off. I'll check and see if mine run without the ignition on. Read the heating posts of a few days ago in this forum.
Can't think of any other fan up front?
From your description, I believe it is an auxiliary heating fan; it should come on when you twist the **** just behind the red levers between the seats. The switch in the levers actually activates the ENGINE COMPARTMENT fan and provides baseline air flow.
Is it under the board directly under your feet or is it on the right side behind the kick panel in front of the door?
There is a blower on either side that hooks into the duct coming through the rocker panels from the back and that is what the previous posts are talking about. If it is directly under the passengers feet then that is something different. That would be someone's "custom" addition.
Wayne
Wayne
[quote]Originally posted by Typical Fish:
<strong>From your description, I believe it is an auxiliary heating fan; it should come on when you twist the **** just behind the red levers between the seats. The switch in the levers actually activates the ENGINE COMPARTMENT fan and provides baseline air flow.</strong><hr></blockquote>
But just to clarify, they are interdependent, i.e. turning the rotary **** between the seats will not activate the auxilliary footwell blowers unless at least one of the red levers has been raised to switch on the main blower at the engine first.
I agree that any fan under passenger floor board, instead of behind the curved kick panel on the right side of the passenger footwell, sounds very odd.
Tim
Tim
It is directly under (or in front) of the passengers feet, not in the kick panel. I can access the fan when I remove the wooden floor board panel on the passenger's side. I do not have the heater type with the levers between the seats. There is only a **** that does turn on the rear engine fan, but not the floor board fan... But I get NO heat! Hummmmmm???
Thanks for all the replies!
MY guess, if the fan is NOT a factory part, or it doesn't look like a factory install...
...is that the previous owner had an aftermarket, maybe even the factory 4-channel amplifier under there and was worried about it getting too hot??![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
That's just a guess, if you could snap a picture of it, and post - that would be helpful.
