911 Forum 1964-1989
Handling problems - any advice?
Old Oct 9, 2010 | 12:56 AM
  #91
theiceman's Avatar
theiceman
Team Owner
i tell ya that 20w50 floews like molases
Old Oct 9, 2010 | 01:25 AM
  #92
rusnak's Avatar
rusnak
I haddah Google dat
Yer one a them ice road truckers, aint che?
Old Oct 9, 2010 | 01:10 PM
  #93
irobertson's Avatar
irobertson
Originally Posted by gdwprice
Hi everyone. I'm still pretty new and learning. I have an '88 3.2 with 103,000 miles. It's displaying a vagueness that has me concerned. Under acceleration the car pulls to the right. Lifting off the accelerator the car wants to go back to the left. This only happens under acceleration and lift off. Gradual acceleration, coasting or braking the car runs straight and true. It's only under hard acceleration and then lift off I get the right pull and then left return. It's noticeable and unnerving.
I recently put on new rear KUHMO tires - replacing the KUHMO tires that were on the car that wouldn't pass inspection. They're standard sizes. I understood the car would squirm a bit on new rubber but I've put 600 miles on them already and it's no better. I'm not sure the tires are responsible but it was immediately after I fitted them I noticed the car felt like it was floating. It was so bad that I had to pull over to check a wheel wasn't loose! Prior to the tires the only thing I noticed was that the car felt vague at the back when I lifted off the power at 90ish and would gather it's composure if I put the power back down. I've had a look underneath and see nothing loose or any play. Any advice would be appreciated.
Very interesting to see someone with exactly the same problem I have.
When I got my car 2 years ago I had this pulling to the right under throttle, and a drifting back to the left when I let off.
First thing I did was have an alignment done.
They found one rear side needed adjustment, this was the first clue to the puzzle, and I thought the problem would be solved.
The result of the alignment correction was that the pulling became 60% of what it was before.
I then had everything inspected and a corner balance done, same pulling to the right.
My bushings are a bit worn, but there is no noticeable play anywhere.
My next thought was possibly a soft torsion bar.
We unhooked the sway bar, loaded up the rear of the car in the centre with a 225 pound human and measured the weight on each rear wheel and the deflection at each wheel arch.
The results were balanced.
This was getting me concerned. I thought that I might have a crooked car, even though there is no sign of any previous collision or major repair.
Then.. I decided to do a cleaning job on my wheels.
While they were off I noticed the tire on the right, the side the required the alignment adjusted, had some uneven wear and was worn more than the left.
Soooo, I decided to swap sides when I put them back on.
Ha ha,, the car now pulls to the Left under throttle and back to the Right when I let off. I flipped the behaviour by swapping the wheels!!!
New tires are in order for the spring.
Then we will see where we stand with this pulling.
Since you have already done the new tires, I would suggest you get the car corner balanced and aligned.
Old Oct 9, 2010 | 02:00 PM
  #94
gdwprice's Avatar
gdwprice
I too started to wonder if the car was crooked - not a good place to let your mind go. I'd probably driven 1,500 miles on the car before putting the tires on so I knew it handled great and all the tires were worn very evenly past the tread bars.
I've returned my tires for (hopefully) a refund and bought 4 new Y rated ones. I can't wait :-)
Old Oct 9, 2010 | 04:25 PM
  #95
Ed Hughes's Avatar
Ed Hughes
When corner balancing the car, you should do it with your weight duplicated in the driver's seat.
Old Oct 11, 2010 | 02:30 PM
  #96
TrackDays247.com's Avatar
TrackDays247.com
Former Vendor
Didn't read this entire thread, but it sure sounds as if the comp/rebound on the right rear is gone
Old Oct 11, 2010 | 03:41 PM
  #97
whalebird's Avatar
whalebird
and a swaybar link disconnected - fr and rr. This is an advantage of spherical bearing swaybar links - at least on the rear of an otherwise stock suspension.
Old Oct 17, 2010 | 02:50 PM
  #98
gdwprice's Avatar
gdwprice
Just an update. I had two new Pilots mounted on the rear wheels and took the car out. The problems are all gone. I can accelerate and lift off the power without putting my hands on the steering wheel and it stays perfectly straight. I didn't put the matching fronts on so I could eliminate other variables so I'll put those on tomorrow. Meanwhile, it's a 70 degree sunny day here so needs must. . . .
Old Oct 17, 2010 | 03:52 PM
  #99
Ed Hughes's Avatar
Ed Hughes
Nice!
Old Oct 17, 2010 | 05:21 PM
  #100
irobertson's Avatar
irobertson
Good to hear.
Old Oct 17, 2010 | 07:10 PM
  #101
rusnak's Avatar
rusnak
I haddah Google dat
I'm glad that you got it sorted out!
Old Oct 29, 2010 | 10:43 AM
  #102
Ed Hughes's Avatar
Ed Hughes
The last 16's I ran in 225/245 were MPSC's which are not for everyone and are now discontinued. Before that was Bridegestone S02's and S03's.
Old Oct 29, 2010 | 01:12 PM
  #103
rusnak's Avatar
rusnak
I haddah Google dat
RIP SO-3s in 245-45-16. So sad! :::sigh:::
Old Oct 29, 2010 | 02:39 PM
  #104
Ed Hughes's Avatar
Ed Hughes
Come to think of it, the R's I run now are being discontinued. Every freaking tire Ive run I the last 5 years is gone now. At least 16/17" versions.
Old Oct 29, 2010 | 09:09 PM
  #105
irobertson's Avatar
irobertson
Ok, now what is this "water" that you speak of?
It's a liquid substance that we here in Canada use to produce electricity.
