Handling problems - any advice?
#48
Yes, I think we found it. It can be wheel bearings, or more likely the hub nut has worked it's way loose. It takes some mongo huge torque, like over 200ft lbs. You need to check the exact torque in the Bentley manual or have someone look it up. Best to rent a proper 3/4" socket and wrench, and a large pipe.
#49
I can't say for sure that your problem is the hub/bearing/axle nut. It just seems like it is, given what you describe as darty and scary handling. I still say the rear wheel is steering the car.
The Bentley manual gives the proper torque for that nut. I just don't recall off the top of my head.
Here is the correct socket and wrench to tighten it, and just for laughs I'll post a pic of the tool I have to replace the rear bearings.
#52
An impact wrench is not the right way to tighten the axle nut...so keep an eye on your tire guys. If you weigh, say 150#, on a 24" breaker bar, well that 300 ft/lbs of torgue under your weight. a BIG torgue wrench is reccommended, the breaker bar is the next best(all with a buddy/wife unit holding the brake pedal)...an impact wrech will not do the job regardless of how much torque the wrench is supposed to make.
I think your on your way here, thanks to rusnak for the "in the field" diagnosis.
#53
I agree, an impact wrench will NOT get it tight enough. If the nut is not tightened to spec, the bearing will not last.
I ended up not using the breaker bar, but instead put the car on the ground, and stood on the wrench handle, with the socket inserted through the center hole in the wheel. There was no obvious flex in the wrench or socket. It's nice to have at least one Wright socket wrench.
#55
If the nut is loose, then the hub will wobble, causing scary handling, then with continued driving the bearing will soon fail.
Course, he won't know until someone checks it.
#56
Ok, here's the bad news, which coincidently is really probably the best news. I sherked my responsibilities and took the wheels in to have the tires swapped. It wasn't free despite having 4 tires fitted to my Honda (they were tirerack tires after all).
No sooner do I pull out of the drive and it's obvious, the symptoms are reversed! Under power it now pulls left and on lift off goes to the right! It must surely be one of the rear tires, right?
#58
#59
It makes a nice upgrade to the early cars because you get the axles with the metal caps over the CV joint, as we all know is a plus if we are on our backs in the garage.
Again, this is from memory - but it stands out insomuch that I recall back dating some track cars. Maybe something new for Ruby!?
#60
I just got off the phone with tirerack and suggested I would wear the $43 for the first install and $37 for the second if they take them back and credit me the cost of the tires. The woman was very helpful and agreed to a refund and free shipping on 2 new ones. I'm done with KUHMO's, does anybody have any recommendations as to what works well on an '88 3.2?
