Rough starts
My 1980 911SC starts up really rough. It sits a lot so I'm wondering if you think it's the gas. The car has no problems once it's warmed up and I've used the high revs for a bit. But when I first start it up it will stall unless I give it gas but it seems like the gas is on and off, pressing the gas doesn't instantly mean the revs will go up. They may, or they may not. It's very odd. I usually stall about 4 times until it can idle without stalling. Until I get the thing warm it does small backfires and the car lurches.
Do you think it's bad gas or a bad filter or what should I check first?
I kinda have the same issue but I don't get any backfire. On a cold start I pump the gas twice before starting and that seems to help. I don't touch it after that. It will idle about 500 and gradually build it's way up to 950 and then it's perfect from there. When I shut it down after a nice drive and start it up about a half hour later it will do the same thing, idle low and gradually build to 950 again and the engine is still quite warm when it does this. Warm up regulator is rebuilt. When I figure it out I'll post it but don't hold your breath, we bought another house... so much to do.
Similar issue here. Because my 91 C2 is using the Motronic DME I don't touch the gas. When she's cold she starts rough and likely won't start on 1st turn over like she used to. Once she turns over she runs rough (like missing a cylinder or so) for a brief moment and then runs smooth from there, still not having touched the pedal. This only happens when cold.
I haddah Google dat
Might be an issue with control pressure and or the Warm up regualtor
http://forums.pelicanparts.com/porsc...em-911-sc.html
John
John
Yup.
Well in my case the gas is good, I have been using premium and gone through a few tanks already this year. I do plan on adding a fuel injection cleaner to a full tank of gas then change the oil after that tank.
If it was a vacuum leak shouldn't it run rough warm as well?
I haddah Google dat
A vac leak would cause it to run lean. It may be that when the engine needs a richer mixture, it stumbles. But a lot of things can cause this, including the WUR, and even a weak fuel pump. You have to check fuel pressure in any case. If you had a afr gauge, that would be the next thing.
I did pick up a new fuel pump and planned to do that anyway. The one in the car is still working but suspect it's wearing down because it can be quite loud at times. I will try that first.
RL Technical Advisor
Your car is losing fuel pressure against the FD when the pump is off so if you change the check valve at the outlet of the fuel pump, you should be OK unless there are other issues (accumulator). ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Naturally, I'm assuming that the fuel filter is nice & fresh,...
Naturally, I'm assuming that the fuel filter is nice & fresh,...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Team Owner
You should not be touching the gas to start a CIS car. check your Base CO and make sure your cold start valve ant thermotime switch is working.
