Fender Mounted Oil Cooler System
I was wondering about the cost to install a front fender mounted oil cooler for my SC. I also want to replace the temp guage with one that has actual temp numbers at the same time. I was given a quote that I thought might be a little high for the work. Was looking to see if anyone had any experience with this job and what they paid to get it done. Parts and labor. I'm being quoted about $1500.
The guage replacement is easy. It comes with numbered scale and a calibrated sender. The high cost is the oil lines and hopefully a Carrera radiator type oil cooler. If it already has a trombone or other cooler up there, then you probably won't need the thermostat in the right rear wheel well. Those solid oil lines can be expensive unless you find someone just wanting to get rid of them.
I haddah Google dat
The factory Carrera fin type oil cooler is the easiest to install. No fabricating and cutting. If you live in a hot climate, run AC, and want to drive in the summer, you should consider adding the electric fan also. You probably could installl the new numbered gauge yourself as a warmup.
Poseur
The hardest part of what you want to do is installing the sender. It goes into the engine near the firewall--top center, roughly. Unless you are pulling the engine--forget it. You can always just buy the kit and put it aside for now, and wait for the next opportunity to do it when the engine is out. You HAVE to replace the sender with that other numbered gauge--or the numbers will be off. Don't be tempted to do one without the other. Many are.
I haddah Google dat
Yup. If you want to have the numbered gauge, it requires a calibrated oil temp sender.
I was just thinking about the OP, and if the quote was for a Porsche cooler, that's pretty decent. You'd need the cooler, two oil hoses, the louvered plate, the body seal, and I think there must be some sort of lower oil cooler mount. You need the upper oil cooler mount, and some way of bolting it to the headlight bucket. If you add the fan, you'll need the horn relocating kit, and two brackets for the fan, the fan, and a relay for the remote switch.
Thanks everyone for the advice. Being the "not good with tool guy" that I am, I will have the folks at Speed Sport Tuning do the job. I am psyched to get it back soon so I can finally do a DE day with it. I had the suspension totally redone about 2 years ago and put in a short shift kit, race seats, harnesses and roll bar. It's ready to have some fun on the track. All it needs now is a 3.6 motor and bigger brakes.
For the oil temp gauge, just go with the overlay from this site.
No need to deal with a new sender
http://forums.pelicanparts.com/porsc...ntage-usa.html
http://newvintageusa.com/911modules.html
Hopefully they are still in stock
John
John
