Is this the relay that goes bad?
Doing some cleaning so I pulled the seat out of my 87 Targa
Is this the one that causes the headaches?
Should I just change it out? Probably orginal device.
also, whats that thing to the left of the relay? It looks like it has some kind of adjustment?
Thanks in advance
Thanks in advance
![](http://i640.photobucket.com/albums/uu130/skiboy/87WB/dmerelay.jpg)
looks to be a 89 production date on it......I'd change it out (However, I'd keep that around for sure).
Back when I checked mine, 5 years ago, I found the original there. Ordered 2 new ones (one to install and the other for the glovebox). Opened up the original, cleaned her up and reassembled,..placed in the "original parts box"...now , when I sell her, I can say that she comes with the original DME relay (kidding).
Best,
Doyle
Best,
Doyle
Impossible for a RUSH disciple to choose a fav, as they all have their personalities (and the surrounding times in which the material was written). I kinda cringed when the keyboards came out but glad they experimented....
As to transitional pieces, no doubt, Moving Pictures is up there. (They be performing the entire Moving Pictures on the upcoming tour). I like 'em all for what they are (individually).
What else is a disciple to say?
Best,
Doyle
S4for5,
Back to the original question... I just changed my DME relay in advance of a recent road trip. I did this with the seat in place, just all the way back and all the way up.
When I did it, I first removed the 10mm nut that holds it down, then I tried to unplug the wiring harness and I had trouble getting it off with my hand sqeezed under the seat and not much leverage.
When I put my new one in, it dawned on me to hook the relay over the bolt *first* then use that as leverage when connecting the wiring harness plug back in place. It was a lot easier that way....
Next time I need to replace it I'll know better and it'll be easier. Just thought I'd pass that on for what it's worth.
Paul
Paul
My old DME relay was dated 1999 and still worked when I changed it just for insurance purposes..it's in my glove compartment.
It's fun to poke around and look at relays. When I changed my blinker relay behind the dash I found it was an Audi/VW unit (turned out not to be the source of the problem anyway).
I just changed mine, in my '88, and it seems to have cured my intermittent starting problem. Haven't driven enough to really know yet, but I haven't had the problem in the dozen times I've tried to start the car since changing the relay.
I found that when changing the relay, I had to have the seat up as high as it'll go, front and back, and have my left hand on the relay, from the front, right hand on the wiring harness, from the back. Then it was easy, just pull to uninstall the old, push to install the new. But it took me a ridiculous amount of time to figure that out--perhaps I'm as slow-witted as my wife claims I am. Anyway, I wish I'd've seen the picture above before I tried this.
One question. I had ordered the spare relay from Pelican a couple of years ago, and it was specified for my year of car. The old one, like the one in the pic, says 15A on it. The new one says 30A. Is that right? Or is the reason the new relay isn't tripping because it isn't getting enough current to trip, and it should be tripping and I'm going to take out something that the relay should be protecting.
In my normally 'urgent' nature, I'd like to get a spare DME relay right away for a road trip tomorrow. Does anyone have part number so I won'd overwhelm the local parts boys?
Thanks in advance for guidance. If I had thought of this earlier, I'd have ordered from a sponsor.
