911SC - introduction and some questions
Hi all, I've been away from the forum for some time but have recently got myself back into a pre-89 car and wanted to re-introduce myself back to Rennlist.
As a daily driver I've now (again) got a 964C2 but of more interest to this forum might be my new track car, a 911SC. It has a fair bit of history as it raced in - and won - the Porsche Club Championship a few years ago in the hands of multiple-champion Ben Demetriou. As such it's a full race car. When I bought it I had it made road-legal again so I can drive it to the track. The car had to remain relatively standard for the race series so runs a pretty standard engine and transmission but everything has been rebuilt and upgraded where possible. It is fully stripped and caged and no fun at all on the road (no heat exchangers, no door seals = cold!) but on the track it totally comes alive and has been fantastic fun so far, including a recent trip to the Ring.
Now that the car does not need to pass race scrutineering I'm keen to do some basic upgrades and wonder what people would suggest? In particular I'm thinking of the changing the air box for an aftermarket kit plus running bigger wheels. The car is currently on 15" BBS alloys which look lovely but I'm looking for a larger contact patch and less sidewall movement. Can anybody help with the following questions?
1. What are the induction kit options for a 911SC?
2. Can I run 16" or 17" wheels? The car is very low at the rear in particular but runs a lot of negative camber so I'm hoping something bigger will fit.
TIA for any suggestions for the above plus anything else that might help me enjoy it even more.
ps - it's fantastic to finally have a 911 for the track with no power steering, the 915 box and that beautiful noise, it's brilliant!
Team Owner
Well he must be from the UK .. he is using that incredibly over used " Brilliant" word that some guy who came to Canada kept using .. but the car looks great and very well set up from the looks lof things .. welcome aboard ...er .. back ...
Come on Ice, you've got nothing to complain about.
I work with a lot of New Zealanders' and everything's "Sweet Bro."
Kusee pee, welcome really nice car.....why does it have 964 sills on it? I'm lead to believe that they are the only ones available now. Did it have a rust repair job??
964 sills? I'm not with you? The side sills have been removed and there aren't any 964 bits on it...?
The welded in sills have the recessed areas with holes in them for the plastic clips that hold the 964 plastic sills on.
On early cars (pre 964) the sills didn't have the holes.
Team Owner
hey Frank are you talking about the area under the door there on the drivers side ? I have a black strip there on mine so i don't know if there are holes underneath. MAy be worth taking off to clean and inspect periodically I would imagine,
http://www.faze-1.co.uk/content/history.php
You can remove your sills by taking off both end caps and then sliding or pulling out the rubber strip. under the rubber are the mounting screws. The bottom of them is fastened under the car. I don't think there is any need to remove them.
A panel beater friend of mine had to replace the rust damaged sills of a 78 car and could not buy the early ones from Porsche. He told me that the 964 one where all that was available.
Because the car he was working on didn't have sill covers on it, he had to cut, weld, and fill all the holes that were in the 964 part.
So can anyone advise on whether I can put 17" Cup IIs on the SC? I've got a set on the 964 which I'm thinking of replacing and putting them on the SC instead. TIA.
Team Owner
er....... did you actually look at my avatar ? actualy mine are aftermarket, they are a great wheel but i am not sure I would track with an aftermarket cast wheel..
Frank .. thanks a lot .. you just KNOW i can't leave well enough alone .. I am sure it will be dirty under there
