Is this a dent from a jack or jack stand?
Is it scratched up on the underside at all? Almost looks like what might happen if you "high-center" over a large speed bump. If not, it looks like a lift arm could have done it too.
No that was probably caused by the recommended way to lift and transport a 911.
You didn't think they still used those silly ramps to get them on the transporters upper deck did you?
https://rennlist.com/forums/rennlist...t-a-911-a.html
You are all awesome. Thanks for the info. Sounds like this shouldn't be a deal-breaker. I may drive out to see this one Wednesday if the one I'm supposed to see today doesn't pan out.
That looks like the leading edge of the driver's side door. No oil cooler lines under there, they are on the passenger side.
Yep, driver's side. Couldn't see the car today but am shooting for Friday. Of course, since I posted the question I've spoken with owners of two other cars. This searching experience is like having a huge crush with no girl to pin it on.
Baby, I personally think that a PO may have hit a road gator or other item that some inconsiderate driver,(damn this political correctness) left lying in the road. It is an easy fix if you have patience. Mark
