Steering wheel removal
6th Gear
I am trying to remove the steering wheel from 1975 911S. I am trying not to brake it while doing so. The steering wheel is the original oiece with a big scare signal pad. Thanks for your help!
I’m not sure from your description what wheel you have but most stock wheel centers from this time frame “pop off” w/a little pressure. Be sure to unhook your horn wire! The steering wheel is held in place by one large nut (24 mm?) & is not on a tapered shaft. Once the nut is off gently tap the back of the wheel to free it, you don't need a wheel puller. Mark the shaft & wheel hub to get it back on straight.
It's always a good idea to disconnect the battery prior to removing the steering wheel. Also check your horn wires for any wear. My horn was going off discrimnately, and I located the source as a worn wire at the point where it meets the horn button. Oh yeah, don't forget to mark the steering wheel position with chalk before you remove the steering wheel!
<img src="graemlins/drink.gif" border="0" alt="[cherrsagai]" />
I replaced the wheel on my 87 over the winter. It was tough to get the nut loose until I went to the hardware store and bought the biggest breaker bar they had. Then it was a piece of cake.
so far as removing the horn pad without breaking it - I was nervous as it didn't just pull straight off or unclip easily, then I sussed that on my '71 2.2 you have to rotate the pad whilst pulling towards you - then it pops off easliy and lets you get at the 27mm nut
