Fuel pump - 944 will work with 911???
I ordered new sealing washers, new rubber mounts, base, clamp, short fuel hose from tank to pump, etc... and incorrectly ordered the 944 pump instead (but was able to call in to cancel that). ![typing](https://rennlist.com/forums/graemlins/yltype.gif)
Now I just need to find a good price for the correct fuel pump and place the order.
Thank you!
Thank you!
http://www.allzim.com/acatalog/Reman...4_928_930.html
Remanufactured for $146
Did you check to see what was wrong with the pump? Is it getting voltage? How many amps is it drawing? Maybe your fuel pump relay is bad. Check these things first if saving money is important to you.
Professor of Pending Projects
N-013-812-2-M30 (QTY-2) - Sealing Ring, (12 X 15.5mm), 911/911 Turbo (1974-89) is the copper seal ring. No need to order the other ones since the pump comes with the check valve and seal rings for that...
I first put gas in the car :P (car already had 5gals in it, it was never empty... I know this because I ended up emptying the tank when I replaced the pump)
I replaced the relay, removed the air filter cover and filter to manually switch on the CIS, checked voltage at the pump, etc...
So yeah, I did my homework before spending the $ on the pump.
I'm 99% sure this is the one i picked up
http://arpstore.com/Bosch-Universal-...B000BZID0S.htm
part number bos-69429
I have the receipt sitting at home i will confirm later this evening
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
Too bad, mine has been working fine after replacement.
