No airflow in center vents
My original post indeed made no sense. I typed it on my iphone.
Those who assumed I was talking about the center vents not bringing in fresh air are correct. I now have the "diagram" printed and I understand.
Engine compartment heater fan blower comes on when either of the red levers between the seats is lifted up...the distribution of the heat is controlled by the bottom red lever on the dash...the rotary fan switch (0, 1 ,2, or 3) between the seats turns on the footwell blowers only when either of the red levers is up...if the red levers are not up, the footwell blowers will not come on regardless of the rotary switch position...when they are on, they boost the output of the engine compartment blower fan...simple, huh?
I asked the same question about my center vents when I got my car because the manual leads you to believe the fresh air blower motor should provide fresh air from the center vents...they forgot to mention that if you have factory a/c that is not true...silly Germans...
Flip all the dash controls as far to the right as possible, then dial up the auto heat control between the seats to 12. You'll feel enough heat in about five minutes to defrost the windows and warm the cabin. Then back down all the controls for toasty comfort. Simple as that.
uninformed gas bag
(contemplating on whether gas bag is one or two words)
