Will Carrera 3.2 Heat Exchangers Fit a 911 SC?
Quit Smokin'
Only difference might be the flange thickness, 84+ Carrera flange I think is thicker, so you would might need longer exhaust studs.
You WILL have problems, and most likely will have to drill out a stud or two
Team Owner
+1
I have a set of thick flange exchangers sitting on my wall because i didn't realize this ( I also have a thin flange 78 ) the rewards are just not worth the risk of trying to remove 12 exhaust studs to put in a used set of exchangers that weren't meant to fit. Figured I would just wait for a local guy with the opposite problem and trade him.
