911 Forum 1964-1989
My build 76 911 Cabriolet turbo
Old 05-06-2009, 12:36 AM
gsmith660
gsmith660's Avatar
I am now a member so lets see what happens now. Some pics of my projects starting with the cab. conversion
Old 05-06-2009, 12:46 AM
gsmith660
gsmith660's Avatar
And the fuse update
Old 05-06-2009, 12:49 AM
gsmith660
gsmith660's Avatar
The bumper
Old 05-06-2009, 12:57 AM
gsmith660
gsmith660's Avatar
chassis stiffening
Old 05-06-2009, 12:00 PM
gsmith660
gsmith660's Avatar
The front seats and 993 rear seats
Old 05-06-2009, 12:03 PM
gsmith660
gsmith660's Avatar
My daughter will enjoy the Porsche experience safely and I think the frame for the seats will add some stiffness to the body. What do you think?
Old 05-06-2009, 12:17 PM
gsmith660
gsmith660's Avatar
Some bodywork pics. I could not get any bodyshop in the area to touch her they all were too busy doing insurance jobs I found a guy who had the highest rep. in the surrounding area to do the paint but he didn't have time to bodywork it so he told me if I would do the bodywork he would paint it for me so this paint job was done for around 1500 dollars not counting my time doing the body.
Old 05-06-2009, 12:52 PM
gsmith660
gsmith660's Avatar
Now the paint. Jack painted all the tins on the car during a driving rainstorm and all was done in my shop the tins had some serious hazing due to the high humidity and we were afraid that it wouldn't burn out but the next day it was all gone and for not being done in a paint booth I think it turned out pretty good. I do have some overspray to deal with but I plan on doing some more on the underbody before I am done. It was my fault I didn't mask off the front as well as I should have.
Old 05-06-2009, 05:12 PM
gsmith660
gsmith660's Avatar
Body as it is now then we go to the drivetrain
Old 05-06-2009, 06:04 PM
gsmith660
gsmith660's Avatar
So here the deal with the motor its a 77 2.7 in good shape I started out to just put EFI with the 3.2 manifold I have had forever then I got the wild hair to go ahead and turbo it. This whole project is a test bed for a purpose built 3.2 later after I get the hang of tuning and what not I will be limited to .5 bar boost at the most but will start out at about 4 psi boost. So here is what I started with and then where I am going. Ben at M&K exhaust supplied the nice bits like the sump plate and wastegate. Also did a heat backdate so I can drive deeper into the season.
Old 05-06-2009, 06:06 PM
gsmith660
gsmith660's Avatar
You know prices are outrageous the exhaust gaskets alone were almost 200 dollars!
Old 05-06-2009, 06:35 PM
gsmith660
gsmith660's Avatar
A few misc. projects get me up to date. I made up a mech. brake light switch, updated dash lights to 5 watt halogen bulbs but I am looking into already changing to e-wire to light up the gauges,a mounting base for my optima battery,redid all the oil lines and fuel lines with stainless braid hose and AN fittings, mounted a boost guage in my clock. The last photo was the test setup to set the reg. and check for leaks.
Old 05-06-2009, 06:44 PM
gsmith660
gsmith660's Avatar
Now I open up to questions, comments, and suggestions. I have other pics if there is something you would like to see then I might have what you need let me know.
Old 05-07-2009, 01:52 PM
mb911
mb911's Avatar
running yet?
Old 05-07-2009, 09:10 PM
gsmith660
gsmith660's Avatar
Nope probably the end of the summer I have a very busy june and early july so wont be much time for the car till after then.
Quick Reply: My build 76 911 Cabriolet turbo
