What is the right size door speaker for an '88 911?
I replaced my door panels last year and elected to leave out the speakers. I've now changed my mind and want to install the door speakers. But what size? The cutouts in the door panel are 4.5" while the hole in the door sheet metal is about 5.25". So what size speakers fit? If 5.5', I assume I have to enlarge the hole in the door panel.
I haddah Google dat
I would be sure to install speaker shrouds as well. They are the bucket shaped things with a cutout at the bottom. They focus and direct the speaker sound outward, and make a huge difference. So, you have to plan for that as well. If you go with 6" you will have a larger assortment of choices. They should fit without too much trouble.
I installed the door speakers according this thread.
http://forums.pelicanparts.com/showt...o+installation
Hey, never mind, I found them on Crutchfield. I was using the wrong term. They are called speaker baffles on the Crutchfield site.
