911 Forum 1964-1989
DIY: Carrera Engine Fuel Line Replacement
Old 02-28-2011, 08:50 PM
  #46
bagger
bagger's Avatar
Great write up Ian, thanks! I may or may not choose the option that you did. Either way though, I appreciate you providing so much information in one place.
Old 02-28-2011, 10:25 PM
  #47
theiceman
Team Owner
theiceman's Avatar
Received 1,102 Likes on 787 Posts
ahhh good times this old thread what happend to the good old days ..
Old 03-03-2011, 02:58 PM
  #48
rusnak
I haddah Google dat
rusnak's Avatar
I noticed a power increase as well, after I replaced my fuel lines. But I also had changed the fuel pressure regulator, cleaned out the ICV, changed all the sensors and clutch...so I wasn't sure what caused it.
What could be the reason(s) for a power increase after changing fuel lines? It's not like the lines were blocked, and pressure is pretty much the same at 37psi.
Old 03-03-2011, 05:50 PM
  #49
dshepp806
dshepp806's Avatar
Mine seems a bit more responsive since changing out everything in the rear...then getting new hoses up front (just to the tunnel, that it) with a new fuel pump.
I've not messed with the regulator....mmm?
Doyle
Old 03-03-2011, 07:23 PM
  #50
Ed Hughes
Ed Hughes's Avatar
Swollen rubber lines?
Old 03-03-2011, 07:34 PM
  #51
rusnak
I haddah Google dat
rusnak's Avatar
That's what I'm thinking. Only Kirk at Zims would know now.
Old 03-04-2011, 09:59 AM
  #52
whalebird
whalebird's Avatar
All the intake gaskets/vacuum hoses?
Old 03-04-2011, 12:34 PM
  #53
rusnak
I haddah Google dat
rusnak's Avatar
Yup, changed all of those those too. But about 4 months prior, I totally went through it and checked for vacuum leaks and did a tuneup for a smog test. And the car was running as well as I could get it to run. It positively screams now.
Old 03-04-2011, 12:58 PM
  #54
whalebird
whalebird's Avatar
It's like giving your dog a bath, they go nuts afterwards.
Old 03-04-2011, 01:17 PM
  #55
Peter Zimmermann
Peter Zimmermann's Avatar
The greatest picture ever posted on Rennlist!
"All the intake gaskets/vacuum hoses?"
- Whalebird.
BINGO!
Old 03-04-2011, 02:11 PM
  #56
Ed Hughes
Ed Hughes's Avatar
Doug's nightmare....and to think he got it back together, AND it ran!
Old 03-04-2011, 05:03 PM
  #57
911tracker85
911tracker85's Avatar
getting ready to dive into replacing the fuel lines on my 911.
last winter, did the 928. cringed as I cranked her over, but she fired right up. hope for the same result with the 911.
Old 03-04-2011, 05:27 PM
  #58
User 4221
User 4221's Avatar
I am finishing up the fuel line replacement (among other things) now.
I scored a deal on new lines and went with OE product. I will cut the old fuel line and measure the ID to see if it is somehow reduced.
Old 03-04-2011, 08:02 PM
  #59
bagger
bagger's Avatar
Scott C,
Where did you score a deal with the OE product?
Art
Old 03-04-2011, 10:44 PM
  #60
rusnak
I haddah Google dat
rusnak's Avatar
During my "nightmare" I kept asking myself: "What would Doug have done?"
Quick Reply: DIY: Carrera Engine Fuel Line Replacement
