Free Panoramas.
Sorry but the classfieds required an account number which I don't have. Here's what I have: Panoramas 2002 Apr-Dec, 2003 all, 2004 all, 2005 Jan -Apr, Jun-Dec. Free to whomever may want them. Cleaning out the garage to reduce the fire loading and so I can park in there again thus things have to go.
Local pickup only, all look like the day they arrived.
Hope someone can use or wants these else they become landfill fodder Tuesday.
Moderators feel free to move this to a generic Porsche area.
Reg
Richmond, Va.
Far West End
Reg
Richmond, Va.
Far West End
They still sit in the garage as the recycle bins are picked up next week. I just didn't want to deal with the hassle of packing and shipping. Plus the concern for damage in the mail and the resultant unhappy recipient.
I'd hate for them to go to the shredder so I'll look into shipping. I have a few days off.
If I could fit the #@&! 911 in a small box I'd mail that too.
Reg
Reg
Let me know the shipping to zip code 53151. I will be glad to pay it to get them. Thanks. You can e-mail me at: carguy@wi.rr.com
Got one. Just can't fit a car in there.
But I'm working on it.
Need to ship the roof off for reupholstering and pull the engine for inspection of and possible rebuilding the transmission. Then seals, then paint then ventilation then . . .
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
It's my fault. I've tolerated the 911's aberations until now. Now my patience has run thin.
Just tired of when it rains having it drip drip on my leg, instrument cluster fog and engine hesitation when it rains hard.
No AC but I'm used to that. Heat that only keeps you warm until the temp drops in the thirties then you freeze.
A tranmission that randomly jams in reverse when placed in reverse.
Peeling clearcoat. (poor insurance paint job by another)
Cracked and dry window/roof seals and rear deck. Other minor and not so minor issues.
Like I said I have dealt with it all but the shifting issue has the car parked. I opened things from the shifter back and replace parts as needed so it must be internal to the transmission.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Like I said the garage is being cleared as best I can. It should be quite a yard sale/goodwill donation/landfill offering.
Once the engine is pulled I hope to do some upgrades. If I don't build that GTM then those funds will go into the 911.
Thanks for listening Ice. You seem to understand.
Reg
Reg
Team Owner
you should do a search on what I did on my car when I first got it , I certaimly feel your pain , but the rewards can be outstanding.
oh wait thi sis the list of what i did before it even rolled it's first mile
Repaired WW pump
repaired headlight pump
repaired headlight pump relay
replaced front rubber impact strip
replaced front marker lens
replaced wipers
replaced steering shaft bushing
replaced front strut inserts
Turbo tie rod upgrade.
replaced brake lines
replaced front wheel bearings
replaced front cargo carpet
replaced antenna
replaced all fluids including brake, gear oil and engine oil
replaced relectric mirror switch
replaced stereo and 4 speakers
removed entire interior down to the tub and refurbished
replaced all shifter bushings and coupler bushings
instaled rear seatbelts
replaced all cv joints
replaced clutch cable
replaced pedal bushings and refurbed cluster
replaced all instrument light bulbs
replaced front sway arm bushings
replaced rear sway arm bushings and drop links
replaced rear shocks
replaced plugs, wires,valve cover gaskets, cap rotor, fuel filter, oil filter,
replaced engine sound pad,
replaced engine deck lid and front struts
replaced heater blower motor
refurbished alternator and replaced bearings
cleaned and polished fan and housing
replaced bumperettes
repaired targa roof panel
Repaired WW pump
replaced wipers
replaced antenna
