911 Forum 1964-1989
life expectacy for Dist. Cap & Rotor ?
Old 10-24-2008 | 07:24 PM
glenncof's Avatar
glenncof
Default life expectacy for Dist. Cap & Rotor ?
I have a 1985 911 which, of course, has electronic ignition. I know what to look for and have replaced them in the past. I'm talking about wear-out, not cracks etc.
How many miles most people get on distributor cap and rotor before replacement ?
Old 10-24-2008 | 08:04 PM
old man neri's Avatar
old man neri
Isn't it part of the 15K service with filters, oil, valve adjust, plugs....etc?
Oh, don't forget to oil the felt if you do it.
Old 10-26-2008 | 01:11 PM
gerry100's Avatar
gerry100
It'sone of those things that deteriorates slowly so that you don't notice.
I realized my cap/rotor had 25K on it, changed it and noticed a smoother running stronger pulling engine.
If they are more than 20k miles old, I'd replace them
Old 10-27-2008 | 02:44 PM
M491's Avatar
M491
Motronic ignition is pretty easy on the cap and rotor. I've gotten 60K+ out of caps and rotors in my other german Motronic cars, and they were certainly worn at those miles, but worked fine.
But they aren't super expensive, 15K seems a little much, but 25K is probably around right.
You can always pop off the cap and have a look.
Old 10-27-2008 | 03:33 PM
djk_wff's Avatar
djk_wff
5th Gear
Wink my cap and rotor ...
My experience is that living on the Atlantic coast, I get about 8-10k miles on a cap and rotor. This is a yearly ritual in changing. There is a white corrosion build on the contact that requires changing. A dremel just doesnt remove it.
btw, I have an '88 carrera with ~160,000 miles. When changed, she purrs and runs like wife used too ...
Old 10-27-2008 | 08:11 PM
dshepp806's Avatar
dshepp806
I do mine frequently....before 10K miles, 4 sure (i know,...I know,..I'm just a fresh copper freak)
Best,
Doyle
Old 10-28-2008 | 05:25 AM
Amber Gramps's Avatar
Amber Gramps
you know it's time to change it when it's hard to start the car after a wash.
Old 10-28-2008 | 05:36 AM
rnln's Avatar
rnln
When I changed mine, just out of curiosity, the old cap and rotor look kind of worn. I couldn't notice any difference. Swapped back and forth, still couldn't tell the difference. Gas mileage is the same too.
Old 10-28-2008 | 11:49 AM
84_Carrera's Avatar
84_Carrera
Legacy Flounder
I went approx. 35k miles on my last cap & rotor. It's something I have meant to start doing more along the lines of 15k miles now (annually).
Old 10-28-2008 | 02:44 PM
theiceman's Avatar
theiceman
Team Owner
i throw one in every couple of years, cheap preventative maintanance really, I have no idea how long they last, and have no intention of finding out.
Old 10-28-2008 | 07:13 PM
dshepp806's Avatar
dshepp806
I've a boatload of 6K mile spares!!!!!!!
...burnished, cleaned,..and put away!!!
Best,
Doyle
Old 10-28-2008 | 08:21 PM
theiceman's Avatar
theiceman
Team Owner
Doyle your ALLMOST as cheap as me !!!!
Old 10-31-2008 | 06:34 PM
glenncof's Avatar
glenncof
I have had my 1985 since 17K miles. According to my records, the first distributor cap replaced by mechanic at ~120K miles.
At ~140K I was replacing oil lines for tensioner and removed the cap. I wish I had a picture ! It looked like the mechanic never replaced it !!
After replacing rotor/cap nothing changed, including gas mileage.
