915 Tranny nut: Which way does it spin off?
Are the threads on the pinion nut (highlighted red in the picture, below) ('72 through '86 915 tranny) right hand or left hard tread?
My research shows this to be a M24x1.5 nut; part number 915.302.282.00.
Mine's really, REALLY resisting coming off CCW as seen, below.
(Just want to make sure it's not a CW nut before I make an all out effort.)
Thanks ahead of time!
250 N-m =... 185 ft-lbs
(cripes!)
Said like Chief Brody in, Jaws: "We're gonna need a bigger (cheater bar)".
Thnks, Pete.
If anyone has words of task-easing advice to break this sucker free, I'm all ears!
(cripes!)
Thnks, Pete.
Having an experienced professional as a tutor is immensely helpful with transmissions - I had the incredible good fortune of attending a one-week Porsche school for manual transmission repair back in the '70s. It's absolutely amazing how much can be learned from a factory-trained expert, that may never be learned otherwise.
We have a distinct advantage today; the digital camera. Every step during disassembly can be photographed, and those pictures can be put to good use. Extreme care and cleanliness should be considered part of the job. You should have a good idea what's inside before you remove the unit from the car. It's not easy, but it can be done.
ps the nut will come off lefty loosie, if you dont have a air comp. take the side shift support cover off and put the trans into two gears at the same time, the trans will lock up and then you can use a socket and braker bar,then knock out the roll pin in the input shaft and remove 27mm nut atthe same time you have the trany locked up. why are you taking the trans apart?
Youse guys are brutal! I remember someone breaking a crankshaft in a 356 using an air wrench to deal with the pulley bolt. The mass of the item the nut is attached to governs the wisdom of air tool use to loosen/tighten. There's a lot of bearings and stuff that get banged using an air wrench here. I'm biting my tongue writing this, going against your sage advise.
