How to lower to Euro Specs?
I want to lower to Euro ride heights. Or possibly a little lower.
I'm getting conflicting info as I research how to do it. Do I have to reset the T-bars to achieve that height? Or will the eccentric lowering bolt allow me to drop it enough?
87 Carrera w/ stock suspension except for new Bilstein HDs.
Thanks,
Shannon
Thanks,
Shannon
Same issue here
Thanks,
Shannon
Thanks,
Shannon
Shannon: I'm pretty sure this is the thread that you need...
https://rennlist.com/forums/showthre...11+by+der+mond
I'll be out of town for a couple of days, so if you post I probably won't answer until Sunday or Monday.
Thanks, Pete. You are as reliable as ever. As I understand it after talking to a local Porsche mechanic... it all depends on where my current eccentric and t-bars happen to be. It's going in to be aligned, so I'm gonna have him lower it too. We're setting it up with a little neg. camber and toe-in so it will be more friendly on the track... and of course less friendly on the new Goodyears going on next week
imho . . .
Lowering your car/re-indexing front & back is a job that every DIYer should try. It puts you into intimate contact with your car's suspension which is a very valuable lesson in how it all works.
It also gives you an opportunity to inspect your A-arm & springplate bushings. For most older cars, you will see that they are probably toast from 20+ years of driving & sitting. Then the fun really begins.
Ian
Ian
Your eccentrics are sure to be in their factory positions, if they've been moved you will be able to see it easily because of spring plate discoloration. Looking at your ride height I'm sure everything (T-bars, etc.) is untouched from original...
Finally, are you really, really, really sure that you want Goodyear tires?
OK, gotta get ready to get out of here, talk to you next week!
