How much should a valve adjustment cost?
As described in the Bentley manual. I have also read that some of the adjuster nuts and rocker arms are difficult to reach/adjust.
Well, it is certainly not as easy as if it were on an engine stand but it is doable. The farthest back cylinders do require some stretching and contort somewhat.
I've done the valves twice. Second time took alot less time.
>>Do you have to remove the air filter cover, heater elbow and A/C compressor?
Yes, those items are easily removed and make for much better access. I did mine for the first time a few months ago. I ended up doing it three times before I was happy and finally figured out the rotate in trick with the custom feelys. Even now I think I have a slightly loose intake valve so at the next oil change I'm going to check them all again. One thing I learned by experience and from others here is it's best to learn the proper way to do a frontside adjust and forget about the backside method.
The thing I don't like about 4 post lifts is that they are really only most useful for storage of one car over another. A mid-rise scissor or a 2 post are more utilitarian for actual wrenching, which is what most here need. I still say my Bendpak is the BEST tool I've ever bought. I'm glad I went thru the agony of moving it out to Calif with me!
I am not an expert but I think the 2 posts can not have 4 wheels up the way 4 posts does, let say you are doing home aignment. With 4 posts, if you want to change wheels, you still jack it up. Or have the option of hydrolic bottle jack like those alignment shop use.
That was my point. The mid-rise and 2 post are more useful for wrenching. The 4 posts are a pain if you have to remove wheels for anything. Anyone that tracks regularly knows what I mean....you're constantly changing tires, bleeding brakes, inspecting, etc. Even alignment is easier with the wheels off the ground, except for toe at the front, IMO.
