Typical valance for '89?
Hey guys, still learning and researching, so this question may come across as ignorant to you, but cut a newbie some slack please! Take a look at the picture below, this is from a 1989 911 Coupe. Shouldn't there lower rubber valance on that spoiler? I've seen some cars with and some without. I'm just wondering what the correct factory standard was, or was the rubber valance optional? Also, what is the part that is sticking out from under the spoiler that I circled? Ok my dumb questions for the day are done. Thanks for any information.
welcome aboard!! Glad to see another Porsche owner in the deep south.
The 84 through 89 Carrera models did not have the "chin spoiler" rubber part you are asking about. They were on the earlier models.
The portion that is circled is actually a crash bar that protects the front of the car, most specifially the A/C condensor which also has it's own metal 'cage' directly around it that is not visible unless you are under the car.
FYI: Something is bent on your photo subject, the protective bar (for the front A/C condenser) should not stick out like the one you show; it should fit like the passenger side of your example. Hopefully it's just the valance pushed back a little, and not something structural under the car.
Maybe you can help clarify... I would assume that if a car is running strictly a front spoiler, this front spoiler was either installed by the owner or it was a dealer installed option. I've never seen an option code for just the front spoiler directly from the factory.
Jay
Pete,
Jay
Jay
Poseur
Back then you could easily purchase a chin spoiler to your car and the necessary clips to install it,--and it helped cover up some of what you ae seeing there. It looks to me like that car took a hit,--probably from a parking lot chock, and it's now not where it should be. I added a chin spoiler to my 1977 S and never experienced any negative handling issues. As technically an 'air dam' its function is to push air away from flowing beneath the car, helping to keep it from trying to fly at higher speeds. The rear device, aka 'spoiler' spoils the rear air producing a downforce in lbs that is a function of the spoiler design and speed of the car. The most effective rear spoiler is the massive turbo tail of 1978 or later which incorporated the massive intercooler found on the 3.3 litre 930 engines. Duck tails do some work, as did the Carrera RSR tail of 1975, but the turbo tail does the most work. Unfortunately, all cars don't look that great IMO with a massive turbo tail on them. They look quite out of balance.
Pete is right. The rubber/plastic lip is part of the optional spoiler package for these cars. And, from the looks of your picture, something is bent.
Here is a picture of an 1988 Carrera with that front spoiler:
