A-Arm Bushings -- While I'm in There....?
I may need a set of A-arm bushings. Is there anything else I can do while I'm in there?
Thanks.
Thanks.
RL Technical Advisor
Yessir, there is,....![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
If the front bushings have deteriorated to the point needing replacement, I'd recommend replacing your swaybar bushings and rear springplate bushings as well. I usually find them to have sagged sufficiently to require new ones.
Steve: Thanks for the response. This may be a silly question...but I'll ask it anyway. Would it make sense to do Turbo Tie-Rods while the front bushings are being replaced?
6th Gear
So, uber903, how does one diagnose the need for new ball joints? On other German car, you can compress the ball joint with ChannelLocks and ANY movement is cause for replacement.
same here, for a while, PB, Neatrix, any other eurethane, or just turn the existing bushing... either way, the task is not small.
Would you post result and thought whatever you decide to go with?
Good luck.
Good luck.
