Valve Adjustment---Two Quick Questions
#76
Howdy folks, I've been working on my valves today too. Used the backside method. I found that the difference between "go" and "no-go" on the .003 feeler was an incredibly small turn of the adjuster screw. With this method, you're trying to hit between .0025 and .003. Its a difference of only .0005! I'm not even sure what that is...5 ten-thousanths of an inch? That is the equivalent of a gnat's eyelash. I've done the valve lash on many a motorcycle, but never have I dealt with such exacting tolerances. I am now half done with my full tune up...valve adj, fresh plugs, wires, cap and rotor. I'll deal with the other side tomorrow (maybe).
#77
It may be 5 ten thousandths of an inch on the back side but its 1.4 times that at the elephant foot. Also remember that the nominal spec is not right in between .0025 and .003...its much closer to .003......people overlook this more subtle concept.
#78
Okie. So I am trying a new image hosting site so hopefully it works. And I was wrong!, turns out the sticker is a silver type colour, not gold as I had previously mentioned.
Here is the sticker. I noticed it is an emissions sticker so I don't know if that effects anything.
Edit: Thinking about this it probably the spec as to how far out of adjustment it can go before it causes emissions problems. Just a guess.
![](http://img155.imageshack.us/img155/5127/lashpc240398sk1.jpg)
Close up of the bottom left corner.
![](http://img137.imageshack.us/img137/5443/lashpc240399px1.jpg)
And for you Doug, what I woke up to this morning, no cool vegetation. Just a bitter wind, a lot of ice, and a C-130 taking off in the distance.
![](http://img165.imageshack.us/img165/4338/lashpc240401pe7.jpg)
#79
don't worry old man, we are plotting our next you tube I think we are going to call it "The Bray Family Tropical Adventure" Shot on location right here at home. As soon as the DSL is back up tonight and Santa is well on his way we will post it for all to see. you can look too.
#80
I haven't read all of this thread, but methinks you guys may be "overthinking" and obsessing about this a bit too much
! I do my valve adjustments the "traditional" way, and I'd bet that most pros have been doing it that way for a long, LONG time. Trust me, it isn't that difficult, and it would appear that some are making it more of a PITA than it needs to be. The first time I did mine, I went around twice (for good measure and just to double check), and she runs like a scalded dog...and that's a good thing!
#81
I went to NAPA and bought a set of feeler gauges. I'm going to try to make a new 0.004" tip for my Pelican tool so I can work on the car tomorrow (yes, that's how I'm spending my Christmas).
I'm sticking to the traditional method for this first job.
I want to double check something. Has anyone else (besides Oshin) experienced the elephant feet sticking to the valve stem? When I started each valve, I had no discernable gap. Couldn't get a feeler in there at all. Even after wiggling it. I only got a gap after loosening the adjustment screw and breaking it free.
So is the e-foot forming a suction fit on the valve stem and actually lifting the rocker arm off the cam?
I assume it's a function of the e-foot having a concave surface (because it's worn?) and acting like a suction cup with the oil forming an airtight seal.
I've not read anything about this on any threads or tech articles. Just double checking myself.
Thanks.
Thanks.
#82
Just finished mine for the first time. I had to wiggle the rockers to break the foot loose from the valve. I had two valves that had to be adjusted, the rest checke OK.
Word of caution about the feeler gauge. I had some from Paragon Products and also some from Porsche. The ones from Paragon were brittle and broke easily. Glad it broke on a passenger side exhaust valve I could see. The ones from Porsche would bend but I never had one break.
#83
So, do you feel confident in your settings? Just wondering how you judged the "feel" of the feeler gauge. I had a friend helping and he seemed to think we were right. But when I double checked using the backside method, I was loose on all of them.
And talking to 964 guy who adjusts valves for a living... sounds like he snugs that thing down tighter than I did.
Despite my frustration regarding the subjective nature of the feeler gauge, I have to admit this is fun
#84
Glad it is going well. I also found that you had to loosen to get the feeler in. Well, I did on my 1st two attempts. Even with the backside, sometimes you try a dozen times to get the feeler in & then all of a sudden it zooms in & you haven't changed anything. Stiction of the oil? Phase of the moon?
Ian
#85
#86
Shannon: It is not the suction between the elephant foot that pushed the valve out. The rocker arm pushes the valve in, however the valve is spring loaded so it is a spring that pops the valve back out.
EDIT: I was really peeved today because I called performance products in Van Nuys, they said they had valve adjustment screws and that they were open until 3PM. I drove all the way there and got there at 1:30PM to find NOBODY there. I was so pissed off.
#87
Sorry to hear about Performance Products. I've dealt with them via internet and phone and I have to admit I've had better luck with Pelican.
#88
#89
Put some oil on the feeler gauge and slightly twist it in. It should be tight, but it will go in. Takes some time and practice. I made the mistake of loosening them all the first time I did it. When I buttoned everything up I discovered most were too loose. I left them loose out of paranoia. Too loose is OK, too tight is bad. Second time was better. If you have to go back in for a second go around, you can do one side at a time. You will only lose a quart or two of oil out of the bottom covers. Just make sure that you turn the pulley 240 degrees for each valve instead of 120.
For any newbies out there, it takes practice, you need to get a feel for it. I work on these things every day and I can adjust the valves in 5 mins or less if I have to, but if you are a DIYer only adjusting the valves on your own car every 15k miles, you do not get the opportunity to adjust them that often. While it is apart, adjust the valves several times in a row to get the feel for it. Hell, do it 20 times if you need to.
BTW get Wrightwood Racing graphite valve cover gaskets if you can, most of the rest are crap.
#90
Let's see. I've spent 13 hours on the project so far, still have about 2 hrs to go. Hmmm.... I guess my first dog spay surgery took 3 hours. Now it takes about 30 minutes. So, I have hope for me and valves!
Now you tell me!
