It cost HOW MUCH?
#181
Nope not the lock rings. I was asking about the outer races. They are not loose but they can be turned in the housing. I looked it up in the workshop manual and they mention heating the housing to remove the races so I take that to me there should be an interference fit. Is this condition not normal like the race on the Diff side of the Pinnion shaft?
#182
#183
The spacer is pressed in with heat, and then the race is pressed into the spacer with heat.
#184
Nice pictures, Pete,.......
This is the time to mention that ALL of these 915 transmissions are showing age-related issues and this is one of the biggest issues. We are seeing a LOT of the aluminum-cased 915's come in with outer races that are either loose in the housing, or have already damaged it requiring an extensive repair.
The fix is to weld the aluminum, machine the housing to accept a steel insert and install a new outer race into that. Frankly, this is how the late magnesium-cased 915's came from the factory and they are proving to be more rugged than the aluminum ones in this regard.
We finish the job adding either a 930 bearing retaining plate or the nice Wevo one and now you have a very rugged and reliable 915 tranny that will give many years of service.
#185
Glad to hear that you're doing case reinforcement! If my guys retire (they're in driving distance for me) at least I'll have someone to send my stuff to!
#187
That's up for debate. I've had the factory steel one for 30+ years, so I've never used one. A recent thread about the plastic tool for a 901 box stated that the tool was not well made (sloppy bearing holes), but I don't know if that carried over to the 915 plastic tool.
#188
Thanks, Pete. I have the 930 one in steel (only way to get it), but I was hoping to save some $$.
Can anyone vouch of a positive experience with the plastic tool? It's too much work to do this job twice, compared with the $$ savings on the tool. Still, I would love to save the $$.
