I replaced the front brakes and rotors on my '88 Carrera over the weekend...
Everything went very smoothly. The most difficult part was removing the dust/grease covers for bearing and rotor removal. Those boogers were really jammed in there. ![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
I also had a caliper piston that was stuck/difficult to compress. I was able to use a C clamp and wood block to free it. No major issues noticed with this/no further problems.
The brakes feel fantastic! The wheel bearing adjustment solved a small problem that I was experiencing. My car would "dance" or wander a short amount from side to side when driving on a flat surface at high speed. I can attribute that to wheel bearing looseness?
The Bentley manual was handy. The whole procedure was very easy. I recommend this as a DIY project for even the most inexperienced shade tree mechanic.
On to the next project.
What brand parts did you use? Where did you get them? I am looking forward to doing this, but it looks like it's not gonna be soon. the drilled Zimmermans look good.
I used a 2" exhaust clamp ($2) on my covers and it was totally easy! saw it on one of the forums...put the clamp on the shallow groove and pry off with a screwdriver on the clamp....would have been really hard without it...
Ed, I am about to do the same thing. I have 928 S4 front calipers with 930 rotors. The factory rotors were $420 each! These are two piece rotors that were only made for the '79-'80 930, so I guess Porsche feels like they have the right to bend you over on them. I ended up buying new custom hats with Brembo rotors from Steve Weiner for only a little more. These things are really a work of art. I am glad to hear it was not that difficult to replace them, though everyone tells me that getting that dustcap off is a bear.
rickdm
rickdm
price off the top of my head. But, they were not expensive.
I used Mintex pads (1st try). I used bearings from my local auto parts store. They pressed the inners, raceways and seals for me.
I do occassional autocross events and a lot of spirited driving. No track events planned.
rickdm
rickdm
Use the muffler clamp on the dust covers-it's painless.
$75 each! Now that seems like a reasonable price for rotors. I know on my Miata you just buy the NAPA rotors for $30 each. of course with the Miata if you need more than the dinky little brakes that it comes with then you are just braking too hard ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
rickdm
rickdm
