20 HP throttle pedal mod
I noticed on my new SC that I wasn't getting much throttle pedal travel. I checked travel at the throttle body and it wasn't even close to WOT when the pedal was at the floor.
The PO had installed (not sure if himself) aluminum pedals and the throttle pedal had two "cups" in the back for inserting the cable ball. Well, it was in the upper one, so was not getting the most of the leverage of the pedal. Moved the ball to the lower one and voila! At least 20 HP!
"Priceless!"
Nice!
I had the same experience with my car. PO had engine rebuilt and the throttle shaft had not been adjusted properly during their engine re-installation. Easiest hp ever gained, and "priceless!"
this was done as cheep insurance. it is very common to do this to a teenager's car, rental car, grandma's car, and yes the family sports car. automatic speed control.
Team Owner
Where is the actual adjustment , I don't think it is on the pedal assembly is it ? is it up behind the CIS area ? time to check out the Bentley I would imagine.
Originally Posted by theiceman
Wowo looks like tonnes of oportunities for improvment , as long as the throtle plate doesn't get bent..
David
