Need "Crunchy Sound "wheel diagnosis assist
My new to me 85 widebody seems to have its first glitch. (50000 mile car) On the last few drives I infrequently heard a sound like I was driving over some metal parts when cornering. Visual inspections revealed nothing. Almost home tonight and a rubbing grating sound started coming from rear passanger wheel,continuiously for last 200 yards. Sounded like something metal dragging .Got home ,removed wheel and as I turned the rotar it felt like grating clicking noises. Pulled the CV and it didnt change anything. Brake pads look new , rotor unscored. Could this be a wheel bearing?? Hand brake works fine if that makes any difference? I need to order parts tomorrow a.m. If im to enjoy the nice weekend ahead. No time left tonight to pull any further but are there really any other possibilities?? Any input appreciated Thanks Doug
Yes, my guess is the wheel bearing. Put the wheel back on and with the rear end lifted, pull the top of the wheel back and forth towards you. If there is play, there is a problem with the bearing.
While rolling, see if applying the brakes changes the sound, then check if applying the emergency brake does. It could be a wheel bearing and it could also be a CV joint.
Team Owner
I would pull the rotor off before doing anything and spin the hub, this will tell you everything you need to know. With the rotor off you will have removed the ebrake from the equation and it sounds like the CV is off already also. Stuff you will have to do anyway to do the wheel bearing.
Team Owner
The ebrake could be a broken expander plate or the pad just fell off the backing. Do a search on Ebrake, I think my pics may still be there, if not and you find this to be the culprit Pm and I will sent you the pics I took of mine.
I have had similar issues with my car. Sounds like a wheel bearing or e-brake to me. I have also had a CV go and for me that was more rhythmic as the joint spun. It was not a continuous grinding noise although it probably could be. The other issue is really determining where the sound is coming from. I thought it was one side and it turned out to be the other.
And the answer is......Inner rear bearing, ground up but no further damage. Im surprised for 50k but mechanic said turbo setup is more prone to this?? thanks Doug This did not look like a do it yourself project for me.
