911 Forum 1964-1989
Engine speed 1986 model
Old Dec 12, 2006 | 11:11 AM
Loaded's Avatar
Loaded
Default Engine speed 1986 model
WHat engine speed is safe for this motor?
Old Dec 12, 2006 | 11:28 AM
KC911's Avatar
KC911
Anything between 3K rpms and the rev limiter kicking in....
Keith
'88 CE couope
Old Dec 12, 2006 | 11:41 AM
Mike Murphy's Avatar
Mike Murphy
Some say the redline is 6,500; others say it is 6,300. In any event, I usually shift at 6,000 to ensure that I keep the engine as reliable as possible.
Old Dec 12, 2006 | 11:44 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
6250-6300 is the tops. If properly maintained you should EASILY be un in that region often. If you drive it at less than 4000 rpm you're a girly man.
Old Dec 12, 2006 | 11:53 AM
Mike Murphy
Originally Posted by Edgy01
...If you drive it at less than 4000 rpm you're a girly man...
It is commonly said that a flat-6 should be run to redline at least once during a drive. These engines like it when you run them up in the rev range. Just make sure that the engine is warm (after 10 minutes of driving, or if the temperature is at least 176F) before you run the engine above 4,000 RPM. After warmup, the engine makes the most power above 4,000.
Old Dec 12, 2006 | 12:05 PM
Loaded's Avatar
Loaded
The PO was a girly man he nearly crapped his pants when i took it over 4k.
Old Dec 12, 2006 | 12:15 PM
madmmac's Avatar
madmmac
If that is the case I would suggest a bottle of Techron and a half a tank of gas...maybe a couple of times.
Old Dec 12, 2006 | 12:24 PM
Mike Murphy
I did Techron on mine and saw no difference. I think the bottle is very safe to use - meaning that you might need to do it more than a 2 or 3 times. Also, it's pretty expensive at near $15 a bottle here in Chicago. Are there any other recommended fuel treatments that can be used? I have a very slight lumpy idle on my car. I think the fuel injectors need to be cleaned a little better...
Old Dec 12, 2006 | 12:26 PM
Jay H's Avatar
Jay H
...then followed by an oil change. I'd throw a new set of plugs in as well.
Seriously, the previous owner didn't rev it above 4000 rpms??? What's the point of owning a 911 if you don't get the motor up spinnin' in the power band??
Red line is 6250 rpms on the '86. The ignition will cut out when you exceed it to protect the motor and auxillary equipment. Porsche recommends (from the owner's manual) that you don't rev a cold motor above 4400 rpms.
Old Dec 12, 2006 | 12:28 PM
Jay H's Avatar
Jay H
Techtron seems to be well regarded in the Porsche world. If Techtron didn't help your idle issue, other additives may not either. I've had good experience with Techtron in other motors for helping with stuck valves and such, so it's good stuff.
Old Dec 12, 2006 | 12:32 PM
Loaded's Avatar
Loaded
Yup did Techron Last night the 20 gal treatment Willl do this now for several tanks. Techron massively improved my 928. what a difference after 2 tanks.
Old Dec 12, 2006 | 12:38 PM
Mike Murphy
I'll run it through again. If that doesn't do it, I might not even have a problem at all!
