G50 Short Shifter
the person who had my '89 Carrera 3.2 before me had a short shifter installed, but I had it taken off for a slight price discount. I've been told that the short shifter isn't really good for the older G50 trans. as it can be for more modern transmissions.
I have a 915 and considered a SS for a while, I was also advised against it as it can be more difficult to shift due to lack of mechanical advantage and can be harder on the gearbox.
I have come to love my stock unit any was and just use it for cruising...
I think WEVO has come out with a G50 short shifter. It's not on their web site so I would give them a call. I have a bunch of WEVO products in my car and they all function well and are high quality.
http://www.wevo.com/porscheproducts.htm
I have a factory short shifter in my 88 Carrera and it works very well. I don't know of any difference from the regular shifter except it is only a couple of inches shorter. When I autocross, I wish I had the standard length.
On a 915 transmission, a short shifter can allow you to hurt the transmission. The internal mechanics work relatively slowly compared to more modern transmission so shifts must be timed. A short shifter does not change how the internal components of the transmission work and therefore allows you to mis-shift by trying to change gears too quickly. I don't know if the G50 is susceptible to the same issues, but I wouldn't be surprised.
I have a weltmeister short shifter on my G50/52 tranny. It requires some minor modifications to the tunnel cover but worth the effort. I know of numerous people that have the same kit and none have noted any issues.
