The problem with Porsches...
#46
Originally Posted by JP Stanley
autobonrun, you know you have a clean SC, when you can sit up above your 993 and not worry about oil leaks. Sweeeeeet.
Although mine runs like new, I think I have a leak from the pressure switch. I replaced the oil return tubes and cam tower lines so they are dry. The pressure switch is on the backside of the engine and I can't reach it without lowering it. It's not a major leak, so I figure it can wait until it's time for a clutch replacement. I have about 109k on this clutch, so I may end up dropping the engine in the next three years or so. The first clutch lasted 101k miles so it may be getting about that time.
#47
Originally Posted by rentadate
...But I paid the State Trooper off $60.00 and I got it reduced to 2 points. Now I have a 4 pointer in the works to go to in June! I'm mad.....
You paid off the cop? Legally?
How does that work?
#48
Team Owner
rnln:
Did it have some extra body parts on it ? the 240Z I saw looked like some kind of very mild body kit was on it and it definitly did not have original wheels. I think these ones were more chrome.
Could it be the same car?
ice ..
what a small world if it is , the guy lives like three streets away from me . He said he used to have one many years ago but he just bought this one last year.
wow....
ice ..
wow....
#49
I think there are several lift companies selling essentially the same lift (i.e. just a couple of manufacturers with many diffent companies selling them under their own company/product name). Research the different companies/prices- I got mine at Superlifts, and then found out there were other companies selling essentially the same lift. Usually there are two sizes- one that goes higher (some companies call it the "SUV" model)- that's the one I have because I have enough ceiling height. Also, many of the companies sell two models- the only difference being one is USA steel and made in the USA, whereas the other is made in China or some other "overseas" area. I think there were other threads where these lifts were spoken about, or if you start another thread I'm sure several of us can post info.
#50
Mr. Ice,
I did something to it but tried to keep original to keep the value since it's one of those first generation. It's 1969, the first year made. No, I don't add but I shave a lot off it. Many times I ran it off the road surface. Scary but fun. It's a car for you to mess it up.. bad. Very light, very reliable.
I did have the front lip and new paint. If he bought it from Arizona, then it's not then. I am in California, 7 hours from Arizona.
The guy bought mine also had one a years ago.
