How many miles do you have on your 911
#31
QUICK ASIDE:
Racer,
Please drop me a line about your '78 SC that is For Sale. I would have emailed or PM'd you but
I believe you have those features turned-off on your account...
Thank you,
Tim
Racer,
Thank you,
Tim
#32
63K on my '80 SC
New to me in '92 with 31K
Airbox replacement (with pop valve) in '01
Fabspeed euro pre-muffler in '05
Carrera chain tensioners (just done)
Carrera oil cooler (in progress)
Only in the shop once (CIS adjustment) since I got it
#33
Originally Posted by jerhic
200813 miles. i had my shop do a leak down test on it last week and and it was 5% of less on all 6. very strong oil pressure hot or cold. Tech sez it good for 100,000 more. i have most of the repair records for this car from day one but i thing the top end must have been redone with these results. no matter what its damned durable!
#34
'70 911E, I'm the 4th owner. Bought this car with 36,000 miles on the clock. Who knows how many times it went around. I rebuilt the motor and trans at an indicated 72,000 miles. It now has 28,000 trouble free miles on the rebuild. I drive about 5,000 miles a year.
#35
'87 with 112,000. Got it a year ago with 108,000 on it. No problems, leaks--a gorgeous car.
#37
122 K and still runs strong. Clutch was replaced a few year back, and I have added some things to the car like new rotors and rebuilding the calipers (didn't need to be done...just wanted the cross drilled rotors) SSI' etc. she doesn't smoke or leak oil @ all, and burns just what it should for an air cooled engine.
#38
1982 911SC 136K No engine or tranny work, Carrera oild cooler, cam tensioner upgrade, pop -off valve, Borla exhaust, Fabspeed bypass, 7x9 Fuchs, 930 brakes, Carrera swaybars, 21-26 torsion bars. Driven daily and tracked 4-6 times a year.
Only maintenence issues have been alternator, and one broken valve spring.
#41
86 911 with 177,000 miles.
I've had it 4 years and don't believe any motor or trannie work was done other than 2nd gear syncro.
I've replace shocks, alternator, rear and soon to be front arm bushings and a lot of little thing that annoyed me.
#42
1988 911 turbo...4th owner, bought her with a little over 57k...just turned 60k
1976 911s...blew the motor last year, has 155k (for sale)
1999 Boxster 145,000 runs like a little blue champion
#43
Originally Posted by tuk_928
QUICK ASIDE:
Racer,
Thank you,
Tim
Racer,
Thank you,
Tim
#44
1984 Coupe with 216,891 miles. Driven nearly every day. Top end done at 170k, trans at 190k. Burns less than a quart of oil between oil changes. Only leaks oil if I stop driving the car.
#45
'82 911 SC with 250,000 approx. miles. (Speedometer was replaced before I got it.) Looks great was running strong when I dropped the engine to go through the trans. (1st and 2nd syncros.) Now that it's out I'll put on the SSI's I have for it and put on the Carrera tensioners, new clutch etc.
Thinking about different cams and maybe a bump to 3.2. Anyway, it's been a great car.
