New 911T Owner, 22K miles
#31
Yikes MM would be a cruel fate indeed. To be fair to Pedro, I think he was only suggesting the carbs be sent there.. not a motor rebuild. I agree with Steve that 15 x 6 wheels would look better, but 16" SC wheels are cheap and available. And they do ride nicely. Except you will need to set the ride height for the 16's and later. As well as the gearing issues Steve mentions. If you can find 15's it's a better deal all the way around.
Vol
Vol
#32
Vol
Vol
#33
Originally Posted by gringo
Also, I thought that the 16" tire had a smaller profile, as to provide the same overall diameter.
Jay
90 964
#34
One of the easiest ways to calculate & compare the effect of alternative tire / wheel size changes to gearing, speedo & etc. is to use the tire manufacturer's "revs / mi." spec. These are included in the specs at Tire Rack (among other places). This yields a % change, high or low. {of course, it is useful to have the OEM supplied tire's rev/mi # for accuracy}
#35
Ked,
I agree that the rev's per mile is the most accurate calculation. I think in this case, we'd never find the specs on the original tires though. So, doing a height calculation based on the tire size would be pretty effective to keep an original diameter even though 16" tires are being used.
Jay
Jay
#36
True, in '71 the OEM tire selction was probably (don't know for a fact) Michelin (XAS), Pirelli (CN something-or-other / 36?), Dunlop &/or Conti. A revs/mi for the Michelin might still be available. I have been curious if the factory established a revs/mi for each model as part of their engineering spec & if that info is available somewhere. Would make a good article in Pano or the 356 Registry... Funny how Porsche tires went from 16" (pre-A) to 14" then back to, & past 16 to 18 & 19". I wonder how the revs / mi for that pre-A compares to the current wheel / tire combos!
#37
#39
After looking for 356s for the last several months, I can not say enough about keeping the car as original as possible. If you have a fully original car, I wouldn't do ANYTHING to modify it beyond factory spec. It will kill value and will make your car no different than so many others.
As Pedro mentioned, get a Cert of Authenticity from Porsche to verify engine and tranny numbers. If those are matching, I would keep the car clean, get the engine tuned up the right way to factory spec, and enjoy it. If you aren't going to show your car, have fun with it but keep it original. It will be worth a ton of money when you get tired of driving or owning it and you will thank yourself you didn't muck with any of the factory parts
Great find it looks like!
#40
Originally Posted by Jay H
Pedro, respectfully, a quick search of Rennlist and Pelican Parts should reveal why a person probably would not want to go to Motor Meister with an original 22,000 mile 911T.
#41
The original tire says, Michelin 165. (I think it does say a couple of letters after that, probably XAS.-Gringo
#43
[edit] ...or, maybe these old tires were never labeled with the more modern tire size labeling that we have now...
A 205/55 16 tire is about 24.88 inches tall. Gringo, you could measure the diameter of the original tire (off the car to avoid any tire sag while on the car) and see how close this original tire is to a 205/55 16. A 10% variance in diameter is probably pretty acceptable. Clearance issues might be something else to consider (and one issue that others could probably answer better than me).
Jay
#44
Thanks for clarifying Pedro! We're all on the same page now!
#45
Gringo,
Did that car come from the east coast not too long ago? I looked at an extremely low mileage '71 Burgundy 911 with 4-speed and chrome wheels awhile back that looked just like yours. The car was absolutely immaculate and all original. I still regret not buying it. If this is your car, you got a great one.
And not to repeat the same thing, but you really should keep that car original, worn out shocks and all. If you want a car to drive, I would sell this one and build up one that is not so pristine.
Whatever you decide, good luck.
