Hi/Lo Beam Switch question
Hello!
Now that my 87 Carrera has (finally) passed smog, I'm moving on to other little problems... Sometimes, when I'm driving at night with the low beams on, the high beams will come on. The switch is still in 'low' position, and jiggling it will get the low beams back on. For now, I'm driving around with the high beams on so it doesn't look like I'm constantly flashing my highs at other drivers (that can get you in trouble
) Is the switch finished?
Thanks!
Thanks!
Actually, if your mechanic is good, the problem can be corrected in about 45 minutes - no switch required. However, about 20% of the time, even if the problem is still in its infant stages, the switch might need replacement.
Pete
Pete
Replacing the switch is an easy job. It has a bunch of wires that connect to the back of the headlight switch. Go slow, and replace each wire one-by-one.
While you're in there and have the steering wheel off, if you're getting play in the steering column from a disintegrated bushing, this would be a good time to buy the "fix" for that. It's also very easy to install, and the part is only about $15. Pelican sells them.
Finally, it's very common for the high-beam switch to go bad. One way to prevent your new one from "toasting" down the road is to install the Sucro relay kit. They're only about $25 and they come with great installation instructions.
Good luck!
Good luck!
Is the switch the same on 73 911E? I just started having the same problem yesterday (although I rarely drive it at night so who knows how long it has been a problem) BOTH high and low on unless I gently hold lever to keep high beam disengaged. When turn signal on, no problem! Any ideas?
My 79 has had the switch replaced twice, it will cure the problem for awhile. As you've stated, if you keep a slight bit of pressure on the stalk the low beams work as they should. I rarely drive with the high beams, so I siliconed a soft rubber washer to the steering column which holds the stalk in slightly when the turn signals are not engaged. I can still turn on the high beams by pulling the turn stalk and I no longer have the problem with the high beams coming on intermittently. If I thought that replacing the switch would fix it permanently I would purchase another switch, but history tells me differently. There are just too many 911s with this problem.
There is a little two prong contact inside the switch that gets weak over time, on my earlier 911s' I'd just take the steering wheel off remove the cover to the switch use a flat duckbill pliers and gently bend them back. I know this isn't much of a description.
Porsche & 911 World had a DIY on this many years ago.
Good Luck
Good Luck
Hi there.
I used the method in this thread and saved myself $100. Plus pride of completion.
http://forums.pelicanparts.com/showt...highlight=beam
Hope it helps. I had drawn a picture of it at one point, but it seems to have disappeared. If you get the wheel off and take the clamshells apart, you can fiddle iwth the switch and it becomes really obvious both what the problem is and how to fix it. You just need to bend the high beam contact back a little.
I did this a year and a half ago, and it's been fine since then.
