1986 - 911 Fan
Originally Posted by LOW13
Any help !!! Would like to get my 11 blade fan redone painted or porcelain?? any suggestions?? am in southern CA. Thanks
Legacy Flounder
If you powdercoat, be aware that the coating is thicker than paint, and can cause an interference with the shroud. When I had mine apart earlier this summer for the alternator replacement, I painted the shroud black & the fan anthracite. Fan stayed ok, shroud paint got beat up a little on the re-install.
When I've done polishing on other cars I've had, they've run hotter, FWIW.
Paint = quick & easy, inexpensive
Coating = durable, longer turnaround, possible interferences
anodizing = beautiful, not as durable as coating
http://www.sinclairmfg.com/fred/911/dcp_3231.jpg
Al Reed in Anaheim can make it look spectacular. He can either powdercoat it to your specs, or just polish and clear-coat it. He does incredible work. You should have the fan housing done, too, if you have it off the car.
Scott
Scott
The down side of powder coating is that the leading edges of the blades will eventually be sandblasted and chip. It is impossible to touch up powder coating and make it look right. I suggest anodizing or paint. CLearcoat after polish is probably the easiest to keep looking good.
Team Owner
Mine has some kind of yellowy clear cote that I can scrape off with my fingernail,in fact it is over most components on my engine. What kind of prep should I do before painting? Also are you talking about regular spray can paint or going to a body shop and getting "2K" paint ( this is body shop paint like when you get your car done, a lot more robust ) I have an air compressor and would consider trying it myself with the right advice. I'd post a picture of mine but I'm too embarassed, it looks horrible. !
