Blinker cancel broke help ???
Well, I just changed the steering wheel and I now don't have the blinkers cancelling after a turn. The left blinker handle will not stay locked down either. I was told that I needed to swap out the original wheel lower plate, no help. Any ideas?
Thanks,
Ron
Thanks,
Ron
This thread from Pelican might help. I have a similar problem so I've been searching it out as well:
http://forums.pelicanparts.com/showt...n+signal+stalk
trelms,
Yes, I marked it and put it at the 3 o'clock position. The one that came with the wheel had been rubbing on something inside. I took it apart today and it looks like the entire bilnker handle assembly may need to be replaced. looking into a part now.
Thanks,
Ron
Thanks,
Ron
Originally Posted by Marv
Is the blinker fluid low?
thanks for contributing absolutely nothing constructive marv...growup dude
regards,
steve
Marv,
Thanks for nothing. Try joining Rennlist and paying your dues or keep your nose out of my questions. I have a simple question that may have a simple solution.
To the rest of you helpful individuals,
I did place the notch at the 9 o'clock postion, not the 3 o'clock position. That is how it was. May have a broken tab in the blinker assy..
Thanks,
Ron
Thanks,
Ron
