Brake light switch again ...ugh!!! Mod or upgrade???
Addicted Specialist
A moment of venting: my goodness, on the 993 the brake light switch has never failed. But on my 1982SC ...argh!!
OK, I hate these dang pressure switches ...why do they have such an abysmally short life, or am I just having crud luck with switches?
So the bottom line: has anyone made a bolt-in kit to bypass these stupid pressure switches with a simple switch that is actuated by the pedal lever (like every freakin car I've owned for decades!!!!) . Sorry, I just had to let that one out.
But yes, please give me some good news, someone!
Edward
Edward
Lost *******phile
Edward
Edward
Here is a circuit that works fine....just use a standard 30a Bosch or Hella relay...
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/1540x2000/brake_light_circuit_as_built_210103_615ad34eb27f8e5cf2ff7cc1ab69d5605d0eff51.jpg)
Edward
Edward
Lost *******phile
Addicted Specialist
Thanks for that gents. But Bill, sir, don't tease like that! What is the mechanical switch that works with these G-cars ...I'd love to put the bucks into getting this fixed forever instead of anther pair of switches and contorting myself into the trunk! I trust this is fabbed solution replete with bracket, switch, etc? Thanks!!! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Edward
Edward
Edward
Edward
switch 911.613.411.00
bolt AM 4x10 900.146.011.02
washer A 4 , 3 900.114.014.01
Addicted Specialist
Ahh, so not an aftermarket drop-in kit, then. Great specifics with p/ns ...thanks sir!!
Now pardon me for asking the obvious, but where (in the pedal cluster, I presume) does the switch go when I get it? Do I fab my own bracket? Any link, or even pics to send me in the right direction?![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Edward
Edward
Edward
Edward
![](https://forums.pelicanparts.com/uploads26/1973_911_brake_light_switch1619727269.gif)
![](https://forums.pelicanparts.com/uploads26/IMG_4245smalljpg1619728068.jpg)
Lost *******phile
I know for sure my '89 G50 does not have it, else I probably would have used it rather than the electrical circuit I posted.
I think though on cars with power brakes, like the OP's '82, I also do not think that bracket was there as the master cylinder is moved and that washer that actuates it is right on the M/C input shaft...so I don't think it will work as simply with the power brake system.
I can't remember the details when I switched my '75 911S to Turbo power brakes I know that pedal cluster did not have the switch mounting tab and I was stuck with the electrical/hydraulic switchs which I rapidly became unhappy with.
So, let's hear how this turns out!
Addicted Specialist
All good info! I will have to first check my pedal cluster ...an 82SC and see what I find. Big thanks, guys, esp for the pics ! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Edward
Edward
My guess is that the "77 up cars w/ boosted brakes won't have the earlier bracket, but it never hurts to look
Any switch will do, the brake light just need an on/off signal
pressure loss warning function is another issue entirely
Lost *******phile
My car is a '76 , no power brake booster
