Front Fender Gasket - 74 911 2.7
Is there supposed to be a rubber seal/gasket between the front fenders and the body? If so where might this be purchased?
Paul--
Are you talking about the area just below the windshield? If so, the answer is yes. Its a gasket about 10" long. You only have to loosen (NOT REMOVE) 4 bolts - the 2 in the trunk closest to the windshield (10mm) and 2 allen head bolts accessed from inside the door jamb.
Its relatively easy, but a major PITA to loosen the 5mm bolts and get the gasket wedged back in.
Can be done however and it looks great when finished.
Dear Paul,
Yes there supposed to be a rubber seal between both front and rear bumpers.
The best parts place that i have found to purchase any Porsche part is with GPR.
GERMAN PART RESTORATIONS , adds in Excellene !
good luck
jpc
good luck
jpc
