Anyone has experience with fitting a 8J on the rear of an early 1969 LWB?
My plan is to run a Pirelli trofeo R 225 in the rear and 205 on the front.
If yes, what ET would work best?
Now I have 195 (7mm spacer) and 205 (21mm spacer) fitted and there is plenty of room to fit wider tires.
your car has ~3.5" of front space and ~6" of backspace, this allows a Fuchs 8ET23.3 from an older 944 to fit w/ a 225/50 tire. It's going to be tight but it is doable, unfortunately those wheels are only available in 16, so instead on a 225/50 a shorter 225/45 would be easier to fit
no, a spacer only reduces ET, you want ~ 8 ET23-25, 8ET10.6 already projects too far and a spacer further pushes it out. That's what a smaller ET does, push the wheel out further
