Caliper rebuild: stuck piston
Addicted Specialist
UGH!! OP here with stuck piston ...and it's still stuck solid!! The last time I did a caliper rebuild (maybe 10 years ago same car), no issues. Today, I went at it and one piston pushes out easily with air pressure (caliper is on the bench), whereas the other piston refuses to budge!! I can neither press that stuck piston back into the bore, nor nor will it move farther out with 110psi into the fluid inlet! Imagine a piece of wood that sits in the caliper as the rotor would; I apply air pressure and one piston pops right up to the wood no issue; the other does not. I am "this close" to dropping the caliper off at a trusted shop to have them do the rebuild.
So last ditch effort, gents: any thoughts on how to get this one piston out? BTW, I tried a channel lock (around the outermost lip so as not to damage the piston, of course), and can't even rotate the piston at all. Ideas??
Edward
Edward
Addicted Specialist
I tried pushing it back into its bore...no dice! How does one "tap" it back in given the caliper is shaped like a "U" ?? All ears here!
Edward
Edward
Team Owner
did it move at all when first attempting ? or has it been that way a while ? if its been jammed a while you may be sol and have to send it away . can you hook a c clamp around it maybe ? or put a piece of flat steel across it then build it out and use a vice to put it back . I had this EXACT issue but i just cant remember how i fixed it.
