83 911 sc
83 911 sc
Recently the idle in my car has changed, It would normally idle at 900 rpm.
at start up and under normal conditions. Now the idle will surge from 900 rpm to 1400 rpm at start up, after it has been driven awhile and say at a stop sign it will idle between 1000 rpm and 1600 rpm.
Does any body have a clue as to why this is happening?
thanks
thanks
Hello, Mike and welcome to Rennlist.
I've moved your post to the 911 Forum
(Click Here), where I hope you will soon be answered.
Hi Mike,
Like you i had the same problem. Changed WUR plus a load of other bits....nothing worked. Then I had the mixture adjusted and that finally solved the problem.
Jon J
79 911 SC Targa Sport - now with 2000 additional miles this month and loving it!
Jon J
I will have to buy a book maybe service manual!
