Is the heater blower motor repairable?
My heater blower motor does not work. The fan wobbles around inside the housing so I assume a bearing is bad. Is there a source for these parts or do I just buy a whole new blower assembly?
I did see a few threads on someone replacing their motor with a new one of non-OEM origin [on the Pelican board]. The level of effort though . . . I just bought a new assembly.
86 cpe
86 cpe
Same thing happened to my 82. I looked into replacing the bushing, but IIRC it is pressed into the plate.
My solution was to backdate the heater. As a stopgap, I removed the squirrel cage and the guts of the blower, and put the empty housing back on. The engine fan moves plenty of air without the electric blower. I drove it like that for a year, and had plenty of heat.
Unfortunately the body of the blower is part of the support structure for the ducting, so you can't easily remove it without changing to the -74 style ducts.
To quote my old mechanic, "The blower is for the women."
Tom
Tom
I bought an SC this spring with a bad blower motor. When the temp dropped this fall, I spoke to my mechanic about it. He said that the high heat and intermittent use causes then to gum up, and premature failure is quite common. He also said the motors are seldom repairable --- but thinking I'm smarter than he is, I decided to take it apart, replace the brushes, tinker for the next four hours, and then throwing it all in the trash, confirming my mechanic's diagnosis.
Replacing with a used motor is a not such a great idea, either --- you're buying something of the same vintage, and failure is just as likely to be imminent. Replacing with new seems to be the consensus.
As for whether you need it at all, the engine fan doesn't move much air below about 3,500 RPM. If you want any heat in stop-and-go traffic (or if your wife does!), I'd definitely replace it.
I took the defective one from my 83 SC to the local German car wrecker. He showed me to the "heater fan bin" I found the exact same motor in excellent condition with a VW 411 part number on it. All I had to do was swap the fan and splice the wires to match the 911 connector.
