718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Let's Talk Track Tires - 2024 Edition
Old 01-23-2024, 12:18 AM
  #61
TRSCobra
TRSCobra's Avatar
RE71RS in 255/35r19 and 285/35/19 just showed up from tirerack. Got the heat cycling option for the first time, too. Can't wait to try these for autocross and track days this year.
Old 01-23-2024, 12:40 AM
  #62
Tigers10
Tigers10's Avatar
Originally Posted by beez
What tracks have you used them on, and what are the ambient temps like?
MSR Houston, COTA, Eagle's Canyon.
Ambient 50-95. I try to avoid too much track driving in the middle of Houston summer.
beez (01-23-2024)
Old 01-23-2024, 01:51 PM
  #63
DER951
DER951's Avatar
Track tire question across all brands: What is the wear rate front to rear on GT4’s?
Will be tracking a GT4 this year after 11 years in a GT3 where rears wore faster, but not twice as fast.
As long as I’m asking, what’s the relative wear rate in rotors and pads?
Old 01-23-2024, 01:59 PM
  #64
85Gold
85Gold's Avatar
In my case front and rear tires wear at about the same rate. Ferodo 3.12 wear about 2 front for 1 rear. Stock rotors 2 fronts for 1 rear. YMMV
Peter
Montaver (01-23-2024)
Old 01-23-2024, 02:37 PM
  #65
Montaver
Montaver's Avatar
85Gold nailed pad wear very accurately. For tires I get two events before they need changing. Depends what tires your running but everything is basically dead by 25 HC. Front shoulders will show a lot of wear, rears always have tons of tread left but are dead from the heat.
Old 01-23-2024, 03:23 PM
  #66
85Gold
85Gold's Avatar
Need to loosen up the rear and drift more.
Concur on the 25 HC metric.
Peter
Old 01-23-2024, 03:49 PM
  #67
beez
beez's Avatar
I'm driving a CGTS 4.0, and for tires (Michelin SC2), I've been getting 2 rears for 1 front tire
For rotors, I'd been getting 2 fronts for 1 rear. Middle of 2023, I changed to AP racing " J-Hook" rotors in the front, and the wear has been remarkably good. On the stock front rotors, I used them for a year and went through two sets in 798 track miles. Both sets were within the 2mm wear limit, but they were badly cracked.
I've been using the AP racing rotors for the last half of 2023, and after 627 track miles, there's still not even a hint of a lip from wear on them. I stayed with the OEM rear rotors.
For pads, I use Pagid RS29 Yellows, and it's about a 2 front to 1 rear ratio. In those same 627 track miles during the last half of 2023, I've worn slightly less than 2mm off the front pads and less than 1mm off the rear pads.
Old 01-23-2024, 03:57 PM
  #68
Montaver
Montaver's Avatar
Peter
When the corner workers are taking their after lunch nap why not
85Gold (01-23-2024)
Old 01-23-2024, 05:50 PM
  #69
Reedy
Reedy's Avatar
Received 1,043 Likes on 462 Posts
Tyre wear is heavily, HEAVILY dictated by your alignment. If you have toe out in the front then expect fronts to wear a lot faster.
I found once I switched to zero toe in the front that my wear evened out to almost equal.
Brakes wear fairly evenly front to rear, slightly more wear in front. More evidence of heat stress in the front rotors so expect them to need replacing before rears. I get about 10 track days out of a set of pads and 20 out of a set of rotors. Slight bias towards front wear but kinda makes sense to replace all at once.
Old 01-25-2024, 08:32 PM
  #70
0-Day
0-Day's Avatar
In the 2023 Tire thread, I had asked about the Bridgestone Potenza Race. This tire was the optional high performance tire option OE on the Lamborghini Huracan STO track special. It was only available initially in the sizes to fit the Huracan STO, which coincidentally has 8.5x20" and 11x20" wheels just like our cars do. I speculated that they should be pretty good given their OE Lambo purpose + Bridgestone's decade long excellence in making great high performance street tires.
Well now the Bridgestone Potenza Race is available in a handful of non-STO sizes too. And GRM tested them! GRM's tire tests have historically been rigorous and excellent. The author and tire tester is Andy Hollis, who is about as good/consistent tire tester as you will get short of a pro race car driver.
GRM found the Bridgestone Potenza Race to be a tad slower than the Bridgestone Potenza re71RS in a track test.
https://grassrootsmotorsports.com/ar...riented%20tire.
In 225/45/17 on a Mazda Miata, the best laps were:
Bridgestone Potenza Race 1:27.6
Bridgestone Potenza re71RS 1:26.9
Now it is possible that the OE STO sized
Potenza Race perform differently than the Miata-sized ones. It's not unprecedented for the same model of tire, especially OE models, to have a different tire compound or even structure. But there you go. Someone actually tested them...
WillyDaP (02-01-2024)
Old 01-25-2024, 09:34 PM
  #71
ExMB
ExMB's Avatar
Received 1,333 Likes on 812 Posts
Not available in OEM or -1 OEM sizing. Even more expensive than OEM Dunlops.
Old 01-26-2024, 12:25 AM
  #72
beez
beez's Avatar
You can say that again! A 265/35-19 is $502!
Old 01-30-2024, 10:27 PM
  #73
madant15
madant15's Avatar
I have been running the AD09 on stock wheels for 3 track days now and I am very impressed. They provide excellent steering precision and the break away in a predictable manner. They do need about a lap to get heat into them but after that they are very consistent throughout a 25min session assuming that you keep the hot pressure around 33-34 PSI, above that they start to get greasy. Talking to my local tech that that works mainly on Porsche and BMW track cars it seems like people are getting about 45 heat cycles out of these with lots of tread still left which I would be more than happy with.
The following 2 users liked this post by madant15:
sdillon (01-31-2024), Treemagnet (03-11-2024)
Old 01-30-2024, 11:57 PM
  #74
KelvinC
KelvinC's Avatar
That's great to hear. I've changed my original plan of going with CR-S v2, to now going with OEM sizing for AD09. It would have been nice if they were as fast as the A052, but you have to give something to get something, and more longevity and more sessions is worth quite a bit for me. Just gotta push a bit harder for those PBs.
Old 01-31-2024, 02:02 AM
  #75
GoodRevrnd
GoodRevrnd's Avatar
Unfortunately, the CS-doesn't come in the sizes I need, and I live in Las Vegas and run at Spring Mountain, but also Big Willow, Thunderhill, Buttonwillow, Laguna, Sonoma, etc., so not sure the Bridgestones will like the heat. That's pretty much why I'm going to try the AD09s first, and see how they do. I'm using SC2s now, so obviously I'm not looking for the ultimate lap time. I think the other manufacturers have made strides the last few years in their compounds, while Michelin hasn't commensurately updated the SC2 compounds since they came out in 2014/2015. So hoping the AD09s are stickier.
Vegas also, will have to hunt you down at the POC and PCA events for tips.
May need to start with the instead of RE71RS. At my skill level consistency and longevity are the most important.
Quick Reply: Let's Talk Track Tires - 2024 Edition
