718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Spyder “accessory mode” and top operation
Old 04-14-2023, 10:11 PM
718socal
718socal's Avatar
Originally Posted by String33
This sounds perfect! Can my dealer do this or do I have to buy a $1k piece of equipment and get a degree from Google? Does anyone know a person in PA who can do this (assuming my dealer can’t/won’t)? Thanks a million everyone!
Try to find someone local with PIWIS. If you can't find anyone, I can do this remotely. Just finished coding two cars in Boston and one in NY. I documented everything in the coding thread
Z06jerry (04-15-2023)
Old 04-14-2023, 10:28 PM
Larry Cable
Larry Cable's Avatar
Received 3,609 Likes on 2,347 Posts
Old 04-14-2023, 10:35 PM
UncleDude
UncleDude's Avatar
Received 5,434 Likes on 2,226 Posts
No need to be offended guys. I don’t mind putting the top up and down manually. The key thing makes no sense. Turn everything off, and then turn it all back on again, and then turn it all off.
I am having a hard time following this lol. I have put the top up with the engine running and not running (key fully to the right). I also use the buttons like Larry, and have never had to turn the car off and on. 95% of the time I put the top up the car is off.
The following 2 users liked this post by UncleDude:
Larry Cable (04-15-2023), rwm (04-17-2023)
Old 04-14-2023, 11:45 PM
String33
String33's Avatar
Key has 3 positions - off, on, and start. You drive home with the key in the on position. You pull into the garage and park and turn the engine off. Now the key is in the off position. You get out of the car and put the roof up. But the hook won’t move with the key in off. So you have to turn the key back to on, re-energize a bunch of stuff, the hvac fan turns back on, etc. Now you hook the roof and life is good so you turn the key back to off, close the door, lock it, and go inside the house.
That’s on, off, on, off. The key fob thing sounds perfect! Thanks again everyone!
UncleDude (04-15-2023)
Old 04-14-2023, 11:54 PM
MrFunk
MrFunk's Avatar
Can't you simply hold the lock button on the fob to latch the roof? I don't have my spyder yet but I swore I saw a vid where the dude latched the roof after putting it up with the key fob
Old 04-15-2023, 12:15 AM
TXshaggy
TXshaggy's Avatar
Received 3,721 Likes on 2,112 Posts
No not on a stock US 718 Spyder.
Old 04-15-2023, 01:18 PM
MrFunk
MrFunk's Avatar
Ah - lame - and as such recommended to code this back in? I'll read through the coding forum...
Old 04-15-2023, 01:27 PM
Larry Cable
I did with the help of @718socal and @Lucifer - highly recommend!
MrFunk (04-15-2023)
Quick Reply: Spyder “accessory mode” and top operation
