718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Post pics of your racing stripes please!
Old 04-27-2023, 08:32 AM
  #61
k-dogg
k-dogg's Avatar
Grey on black…from Renndecals. Let’s hope they stay on…
The following 4 users liked this post by k-dogg:
850tgul (04-28-2023), GTS992SA (04-30-2023), TriggerHappy (04-27-2023), UncleDude (04-28-2023)
Old 04-27-2023, 10:25 AM
  #62
4S Leistung
4S Leistung's Avatar
The following 3 users liked this post by 4S Leistung:
GTS992SA (04-30-2023), l30thelion (04-28-2023), TriggerHappy (04-27-2023)
Old 04-28-2023, 08:30 AM
  #63
bmf1
bmf1's Avatar
The following 3 users liked this post by bmf1:
Carrara Design (04-30-2023), GTS992SA (04-30-2023), l30thelion (04-28-2023)
Old 04-28-2023, 12:45 PM
  #64
850tgul
850tgul's Avatar
Wow, fantastic combo! I had the same on my 997.2 (black car, grey decals, yellow calipers) and always thought it all went very well together. I've used Renndecals before and they are a quality shop with quality decals. Just make sure you don't use a "grabby" wash pad when going over the decals and you should be fine.
The following 2 users liked this post by 850tgul:
Carrara Design (04-30-2023), k-dogg (04-30-2023)
Old 06-02-2023, 02:09 PM
  #65
BoxKing
BoxKing's Avatar
Default PORSCHE TRIPLE STRIPE MATTE BLACK
Just installed these yesterday morning.
1 1/4" from bottom of the door panel to the bottom edge of the horizontal stripe.
1 13/16ths from the upper curved edge to the door panel.
SpyderSenseOC (06-02-2023)
Old 06-02-2023, 02:14 PM
  #66
SpyderSenseOC
SpyderSenseOC's Avatar
Received 1,344 Likes on 805 Posts
Nice and clean. Any difficulty getting the decal to wrap around the curves at the door edges and fenders? I used some binding clips to hold things in place where it wraps around the trailing edge of the hood. But next time I'll probably get a nice firm piece of rubber hose and slice it longways and slip it over the edge for a more uniform and uninterrupted grip.
Old 06-02-2023, 02:27 PM
  #67
BoxKing
BoxKing's Avatar
No issues. I used panel wipe (PREP) to all areas that the vinyl was been laid down on. I also made sure no to touch the inner side of the vinyl as much as possible to ensure the pieces had optimum tack.
The trick is to go UBER slow when you're laying them down... this will help prevent most of the air bubbles from being trapped. A needle poked in the center will clear any you may find right up, which is something I need to do over the weekend.
Tip: Before you pull the outer film off to reveal the glory.. make sure to run your finger over all the edges with a good amount of pressure to lock in the seals. This also aids in making sure they stay applied once you peal off the outer later.
IMO, the hardest part of laying down vinyl is choosing the initial measurements - it was a breeze once I committed to them.
Old 06-02-2023, 02:35 PM
  #68
SpyderSenseOC
I resisted the urge to ever poke them with a pin because I just didn't want to allow that passageway to exist. Instead I just went real heavy on the soap solution and worked all of the bubbles out with a plastic vinyl tool with felt edge that I picked up on amazon as part of a kit. Came with an exacto, extra blades, a couple of squeegie-like tools and some other misc bits.
Amazon Amazon
Old 06-02-2023, 06:37 PM
  #69
BoxKing
BoxKing's Avatar
That kit would work well for these applications. I just used a credit card, and box cutter. I have a few smallish bubbles that I was going to poke at today, but honestly, I’m in limbo as to whether I like the decal. I dont walk away from the car and feel/see that “wow factor” when I turn my head to look back at her now that I applied the decals. It just doesn’t look as clean to me, at least at the moment. Stick with it, or peel them off is the question?
Old 10-11-2023, 08:57 AM
  #70
Jg3 customs
6th Gear
Jg3 customs's Avatar
Silver with Porsche yellow waist line.
Old 10-11-2023, 08:58 AM
  #71
Jg3 customs
6th Gear
Old 10-11-2023, 08:59 AM
  #72
Jg3 customs
6th Gear
Old 10-11-2023, 09:01 AM
  #73
Jg3 customs
6th Gear
Old 10-11-2023, 11:49 AM
  #74
BoxKing
BoxKing's Avatar
Originally Posted by Jg3 customs
You didn't think applying a side door decal that read "SPYDER" would have been more fitting??
Even adding a red stripe in place of the yellow to tie in the calipers.
UncleDude (10-11-2023)
Old 10-11-2023, 12:04 PM
  #75
UncleDude
UncleDude's Avatar
Received 5,431 Likes on 2,225 Posts
Might as well put Misson X on the side of it LOL.
Quick Reply: Post pics of your racing stripes please!
