Oil Change on GT4RS
#61
FYI - Someone posted an entirely new black plastic oil tank drain plug on his 992 GT3 (June 2023 production) and I assume this new tank and drain plug may show up on late production GT4 RS as well. Previous version was metal with captive o-ring (6mm female hex head). New one can likely be managed without a tool (bare hand).
Here is a pic (see left side of photo):
#62
https://www.suncoastparts.com/product/sku992gtdpf.html
#63
Not sure of the part number, but can order it right here:
different sets of answers.
"Our filter kit comes with a rubber sealing gasket and a unique drain plug.
Oil Filter Kit : Suncoast Porsche Parts & Accessories (suncoastparts.com)
Let me know if you have any other questions, thanks again!
Mit freundlichen Grüßen / Sincerely,
Suncoast Porsche Parts Team
www.SuncoastParts.com"
I think the final maybe correct. But sounds like there are a few options of parts number on 992 GT3s as well.
"Here are the part numbers included with the kit.
PK718GT4RSOIL RS FILTER Kit
PAF-013-844 SEAL RING 1
PAF-911-559 SEALING PLUG 1
0PB-115-351 OIL FILTER 1
9GT-115-647-B SEALING PART 1
Aldo (SuncoastParts.com)"
#64
Ive reached out to them a couple times and they weren't sure what the kit consisted of....I got 2
Kits for 992 GT3 (and presumably the 4RS also) come with metal bodied spin-on oil filter, drain plug and separate crush ring for engine drain and oil tank drain plug (either metal with captive rubber o-ring or plastic cap version, depending on vintage of car).
#65
My link is just for the oil tank drain plug.
https://www.suncoastparts.com/produc...8gt4rsoil.html
GrantG (10-30-2023)
#66
yeah sorry, my info was what they actually have listed for the GT4rs on their website, and additional email dialogue.
#67
Cracked open mine to see what parts I had
#68
Also got a bit of roadkill blood on the what I believe is aluminum subframe. What would be the best product to use on the rear subframe to clean?
#69
Those are the standard metal drain plugs (sump and tank). The tank only began to use a plastic plug very recently (second half of 2023).
You can see lettering around the circumference of the tank drain plug, which indicates that it is using the upgraded part (number ending in “B” that means it shouldn’t be too difficult to remove like the ones made for MY2022). If you want to be extra sure not to loosen the fitting, break loose while engine cold (as described in the Technical Service Bulletin).
Airbag997 (11-22-2023)
#72
Bringing it back to Oil Change....Mobil 1 ESP Full Synthetic Engine Oil 0W-40 1 Quart
Autozone has a deal going on:
$37.99
Save on 5 Single Quarts of Mobil 1 Full Synthetic or Mobil 1 Synthetic High Mileage Motor Oil and an STP Extended Life Oil Filter
https://www.autozone.com/motor-oil-a...rt/1177215_0_0
I ended up buying an oil filter for my 2000 Jeep Wrangler. I'm not sure if I can return it and still get the deal on the oil.
#74
Matt
#75
The plastic plug requires a different tank fitting (plastic stays plastic and metal stays metal).
matttheboatman (11-23-2023)
