718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
GT4 to GT3
Old 12-30-2022 | 12:09 PM
  #31
YMGT4's Avatar
YMGT4
Originally Posted by JCviggen
My main issue with the GT4 I suppose was that I had to sort of ruin it as a road car in order to get the performance I wanted on track. With about 465 HP at the crank my GT4 felt "right" power wise, but the only way to get that was a serious full exhaust system that was loud and droned.
This is my same exact feeling. I ruined the GT4 for the street trying to make it go faster on track. The GT3 just does everything well stock- first car I didn't want/need to modify.
The following 3 users liked this post by YMGT4:
jwr9152 (01-02-2023), Larry Cable (12-30-2022), LZRD GRN (12-31-2022)
Old 12-30-2022 | 12:47 PM
  #32
TXshaggy's Avatar
TXshaggy
Originally Posted by Adrift
The GT3 has close to the same second gear vmax as the MT in the gt4/spyder. You may get there faster, but you will be going just as (illegally) fast.
I've never seen a car forum more obsessed with Vmx of 2nd gear.
The shorter gear set accomplishes greater torque multiplication and pulls harder in every gear. You don't need to get to Vmx to experience that effect.
The GT3 has a shorter overall ratio with each individual gear ~15-20% shorter.
The following 2 users liked this post by TXshaggy:
Bearrun21 (12-31-2022), Larry Cable (12-30-2022)
Old 12-30-2022 | 12:51 PM
  #33
Adrift's Avatar
Adrift
The "tall gearing" complaint I have always heard is with respect to how much shifting you get to do before you are beyond legal speed limits, not how hard it pulls. vmax reflects that limitation.
You are in no better situation in a gt3 for this specific criteria than in a gt4/spyder.
That is my point.
If you're doing your whole canyon run in second gear in a gt4, you'll be doing the whole canyon run in second gear in a gt3 as well (assuming you don't short shift)
Traind (01-10-2023)
Old 12-30-2022 | 01:42 PM
  #34
TXshaggy's Avatar
TXshaggy
That is my point.
If I hear correctly what you're saying, is that you always run your car to redline before shifting, and that point expressed in MPH (in 2nd gear) is similar in both the GT4/3.
In your canyon run example, yes if you are shifting at redline always then both are probably in 2nd. What I'm trying to say is that with a 20% shorter box you're in third much more as it's pulling like 2nd. This shorter ratio set-up does promote more shifting.
Old 12-30-2022 | 02:27 PM
  #35
KelvinC's Avatar
KelvinC
Originally Posted by needmoregarage
I’d say it boils down to personal preference. The “better” car depends on definition of “better”.
Personally I prefer mid engine and the smaller and more nimble feel of the GT4. I have owned three 911 (992, 991.1RS and 993), and 5 mid engine cars (Cayman R, two 981GT4, current 718GT4, Lambo). I’ve also had a C6 Z06 and SL55AMG (front engine RWD). For me: mid engine is best.
If your definition of “better” is 0-60 or lap times, the 911 might win. If your definition is a particular way it feels to you, then the Cayman can be the “better” car. I also love the lines of the GT4.
There is no right or wrong when it comes to personal preference. I say to each their own. And aren't we lucky to have amazing choices when it comes to engine placement, NA v turbo, RWD v AWD etc.
+10000
Goodness.
Other than comparing lap times set by like-for-like drivers, there is no “better” other than what what each of us prefers, individually. It’s all subjective.
This forum is so full of people making absolute statements based on their own, subjective preferences.
Theres nothing wrong with having a difference of opinion or experience than others…there’s just no need to shove it down everyone’s throat as if it’s fact.
And a car is about more than its lap times…how it looks, how it sounds, etc. these are personal preferences that make a huge difference for a sports car.
The following 10 users liked this post by KelvinC:
6IXSPD (12-30-2022), fxmixer (01-06-2023), Jamipurs (01-01-2023), jimdillard (12-30-2022), Larry Cable (12-30-2022), lilbza (01-05-2023), needmoregarage (12-30-2022), tigerhonaker (12-30-2022), Traind (01-10-2023), Z3papa (01-05-2023) and 5 others liked this post. (Show less...)
Old 12-30-2022 | 02:58 PM
  #36
JCviggen's Avatar
JCviggen
Originally Posted by batasrki
Does this not describe the DeMan treatment of a GT4?
Not entirely, no. And certainly not for a European like me who has an ocean between himself and DeMan. I'm not getting a 50 grand engine with no effective warranty which may or may not stand up to long term track use and if it breaks I get to argue with someone on the other side of the world about it as opposed to a Porsche dealership with the car under extended warranty... Besides that, it still doesn't really sound like the GT3 engine and adding stuff like x-pipe exhaust just makes it less liveable again.
The following 4 users liked this post by JCviggen:
Gorthaur (12-31-2022), Larry Cable (12-30-2022), Montaver (12-31-2022), TDT (12-30-2022)
Old 12-30-2022 | 02:59 PM
  #37
Larry Cable's Avatar
Larry Cable
Anyone else a bit tired of the constant repetion (by a few known sycophants) of "<known aftermarket provider name here> completely obsoletes any factory gt4/spyder offering"?
A converted car is NOTHING LIKE a regular car. With the increased performance, it brings a ton of risk, usually a number of personality quirks, as well as the fact the car loses most of its open market value immediately. Of the niche set of people that want a GT car, a very niche niche set want a conversion GT car.
So stop already. Good for you. I am sure it is awesome. Enough with the drum beat that it is the obvious, better solution. For most people, it is not. I sure hope you get some return on all the pandering.
Note: This is in no way a critique of the vendor being discussed. I am sure they make an excellent product(s), of which I may indulge at some point (shorter gear set?). But a converted car is NOT a factory car, and to pretend it is a no-brainer upgrade without any downside is completely false / disingenuous.
frankly yes.
The following 2 users liked this post by Larry Cable:
JCviggen (12-30-2022), Montaver (12-31-2022)
Old 12-30-2022 | 03:01 PM
  #38
Larry Cable
Originally Posted by KelvinC
+10000
Goodness.
welcome to (internet) social media ... and why I continually ask myself why I bother... sadly its an addiction.
KelvinC (12-31-2022), MechEngr1287 (12-30-2022)
Old 12-30-2022 | 03:12 PM
  #39
Larry Cable
completely agree!
I had a pretty awful experience back in the internet bubble days converting my 993 C2S into an RS "tribute", even with a factory 3.8L powerkit etc I would never again modify a car's drivetrain from factory, when it all goes wrong you
are lucky to be left with a car you can sell on the open market, I was lucky to get KBB for a car that had nearly 2x its MSRP invested in it - mostly because of the disreputable practices of a very well known Porsche engine
builder in N Ca.
I also spent quite a bit on my 964 RSA (but not the engine having learned my lesson earlier) another car I never recovered the R&D investment in...
I wouldn't put anything on a car that I could not take off with the tools in my garage ... not too mention that the weakest performance part in any car is typically the driver (Me) - when I'm turning factory driver laptimes at the 'Ring I'd
consider other performance modifications...
we might as well buy a racecar like a Radical - they leave GT cars standing still!
The following 7 users liked this post by Larry Cable:
fxmixer (01-06-2023), Jamipurs (01-01-2023), JCviggen (12-30-2022), LZRD GRN (12-31-2022), Montaver (12-31-2022), sdillon (01-01-2023), TDT (12-30-2022) and 2 others liked this post. (Show less...)
  #40
jimdillard's Avatar
jimdillard
You can solve the sound "problem" pretty cheaply, IMO (assuming your local regs allow you to remove the GPFs): Soul OAPs and a VC: job done. Sounds pretty amazing.
Fully agree. I've got the same and smile every time I hear it!!
tigerhonaker (12-31-2022)
Old 12-30-2022 | 03:51 PM
  #41
dmboone25's Avatar
dmboone25
It appears to me that the GT3 is a much more "serious" car, if that makes sense. Higher limits, higher price tag, all of that. Really depends on what you want out of the experience.
The Spyder is great - I really like it, especially with the exhaust modifications I've made. Do I lust after the GT3 engine? Yes, but I would rather have it in the Spyder. That would be the best of all worlds.
But I can see the draw of the GT3, and of the "progression" up the chain, so to speak.
The following 3 users liked this post by dmboone25:
jimdillard (12-30-2022), Larry Cable (12-30-2022), MaddMike (12-30-2022)
Old 12-30-2022 | 04:04 PM
  #42
Larry Cable
get both!
jimdillard (12-30-2022), LZRD GRN (12-31-2022)
Old 12-30-2022 | 04:38 PM
  #43
jimdillard's Avatar
jimdillard
Originally Posted by Larry Cable
get both!
Problem SOLVED!!! Now what are we going to talk about?!
Old 12-30-2022 | 04:47 PM
  #44
Larry Cable
ah ... well ... h'mm ... errr... gosh ... ummm ...
Old 12-30-2022 | 05:12 PM
  #45
Bucketlistx911's Avatar
Bucketlistx911
Default I took the easy answer “both”
the GT 3 and GT 4 are very very different cars. Love them both and drive them for different experience. The GT 3 is a performance monster. The engine is a high revving powerful beast. Mine is fitted with the PDK. Running that car through a series of curves and accelerating sections of road is exhilarating. The GT 4 is manual and tons of fun to play with on the right road. Enjoy the sport car dynamic of steering and shifting gears. Here is a real a:b comparison. On a back call it country road posted 45 mph, curve ahead sign 30 mph. Ok in the GT 4 smile and select second and pull that corner at 50-55, great fun. Ok take that same corner in the GT 3, look down and you peg 60-65 and that car whispers you are a wimp if that is all you ask……..the GT 3 is magic, the front end is unbelievable. The differences on track are well documented, a good driver in a GT 4 can be right with a 911 and faster than many drivers. The biggest difference is cost, a GT 4 at $125k, a GT 3 at market $250k. The real value difference is not 2x but that is todays market. I would advise start with the GT 4 if economics matter. gosh I love them both and it is a dilemma sometimes, which one to drive today?
The following 3 users liked this post by Bucketlistx911:
jimdillard (12-30-2022), MechEngr1287 (12-30-2022), tigerhonaker (12-31-2022)
Quick Reply: GT4 to GT3
